Results 1 to 10 of 11
Thread: somethings catching when wheel is turned
    Aug 2012
    basingstoke
    Default somethings catching when wheel is turned
    My mate has just brought an 08 vectra c ellegance(i think) and he noiticed that when her turn the wheel half lock theres a slight knocking noise comming from the passenger front wheel.I had a look tonight and noticed that when he turns its seems that the coil spring is catching on something as its turning.Ive had a feel along the spring and it didnt feel like it was broken so im not sure what it could be.
    Anybody got any suggestions i could pass on to him?
    Hanging Heaton / Batley
    14 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    Spring sleeve maybe, could be the metal on metal when turning causing it to twang etc...
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Either that or the strut top bearing is knackered. It causes the spring to stick, twist and then jump as you turn the steering
    Aug 2012
    The spring Shouldn't turn with the wheels but may move if the top mounts are loose or kaput. Does the noise happen with no forward or reverse motion? If it happening while moving it could be the CV joint perhaps.
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    The spring does turn with the steering, i've built enough Vec C shocks up to know that
    Aug 2012
    Quote Originally Posted by John IS3 View Post
    Really??? Actually turns? Or do you mean the whole assembly rotates?
    PS: Do you know what the average ride height should be for an SRI above a standard tyre and rim? As in how many cm's from top of tyre to arch - roughly? Just wondering if my springs are snapped.
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    The whole assembly rotates but the bearing on the top mount can seize and or collapse which stops the spring turning smoothly with the strut.
    I'm sure the is a thread with hub centre to wheel arch measurements on here
    Aug 2012
    Will see if I can find it.
    Thanks for the reply
    Aug 2012
    basingstoke
    Thanks for you replies guys i will pass it on to him.
    Its definatly not CV related because it does it when the car is stationary and you can see the spring kick/flick slightly when the steering wheel is turned.
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Quote Originally Posted by justin33 View Post
    Guessing it's making a bed spring twang sort of noise too?
  1. steering wheel catching keys
    Last Post: 23rd April 2011, 20:59
  2. Knocking catching noise
    By Rebellion8878 in forum Vectra C / Signum Car Chat
    Last Post: 30th December 2010, 22:58
  3. It's catching!
    By MLC in forum General Chat
    Last Post: 5th July 2006, 23:22
  4. It's Catching
    By Gripper in forum Quick Photo Album
    Last Post: 18th April 2006, 23:39
vectra steering wheel catching on something when turning
