Results 1 to 10 of 22
Thread: Alternator Problems
    Jul 2012
    Derby
    Default Alternator Problems
    Hey all on the way home tonight the alternator light came on!
    I drive a 54 plate Vectra C 1.9 150 estate and I've tested the battery when running and only get 11.7 so I can see its not charging. I was wondering if there is a fuse or relay that could have gone or is it change the alternator?
    Any help is appreciated!
    Regular Member um20's Avatar
    Mar 2007
    Doncaster
    Most likely to be the alternator mate, I had the same thing happen to me only last week. If you're handy with a set of spanners and have a few hours spare it's a DIY job, I did mine with the help of the excellent How2 on the site. I had 11.7v at the battery, and the car died on the way home from the folk's house (luckily my Dad was following as we predicted it would die). Once the alt was changed it was showing 13-14v at the battery with engine running.
    Whilst you're at it you might want to consider changing the belt too, it has to come off anyway and it's only £20 (well, mine was). Easy to put on too, damn sight easier than the belt on our Mondy was!
    Jul 2012
    Derby
    Yeah I though it would be. Luckily I got home! Yeah I will do it myself just spotted the how to it looks like the Astra I had and had to change the alternator on that to! Yeah common practice to change the belt rude not whilst its off.
    Aug 2012
    Just before you do change it get a multi meter and test the voltage coming off the alt. You never know it may be a bad earth causing the battery to not charge.
    Jul 2012
    Derby
    where do you test that?
    Jul 2012
    Derby
    sorry which connection on the alternator?
    Aug 2012
    on the terminals of the alternator itself. If its around 13.5 v plus then its probably still good. Just put the meter across the two terminals on the back of the alt (or one on the case and one on the positive if it only has one terminal). If you get the higher reading (13.5 plus) when measuring Volt DC then you probably have a bad earth Path. To prove it try clipping a jump start cable from the alternator Negative terminal to the battery neg or from a nice clean bit (maybe sand it clean) of alternator casing to the battery neg and see if the warning goes off. Basically meter goes on the points where the alternator electrically first connects to the rest of the car via wires or its own casing.
    Jul 2012
    Derby
    Thanks for that I will give that a try in the morning.
    Aug 2012
    be sure not to connect the positive to the body of the car (negative) though mate as you will take out the main fuse and maybe worse! Its no more dangerous to do than a jump start this form of testing with a jump cable but just make sure you get it right. Check then recheck :-)
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Interesting bit i like to know. Where to check for bad earthing point connected to altnerater? As my battery light keeps appearkng 5 minutes of driving but tested fine. Am thinking maybe earth issue.
  1. alternator problems
    By tyler boy in forum Electrical & ICE (including SatNav)
    Last Post: 10th November 2011, 19:19
  2. alternator problems
    By webtrawler in forum Vectra C / Signum Car Chat
    Last Post: 29th September 2011, 08:09
  3. Alternator problems??
    By chrisvectra in forum Vectra C / Signum Car Chat
    Last Post: 13th May 2011, 12:05
  4. alternator problems
    By bran.c in forum Electrical & ICE (including SatNav)
    Last Post: 20th January 2009, 23:50
  5. Alternator problems
    By AJA in forum Electrical & ICE (including SatNav)
    Last Post: 27th August 2006, 07:58
