Results 1 to 3 of 3
Thread: Rocker Cover Gasket Leak Symptoms?
    Regular Member john506's Avatar
    Mar 2011
    Wirral
    Default Rocker Cover Gasket Leak Symptoms?
    Done a search but not many answers out there,
    Got oil leak by vacuum pump at front of the engine, seems to be coming from rocker cover seal.
    Is it a biy job for a DIYer? Do you have to remove cambelt to take it off?
    What are the symptoms of rocker cover gasket leaking? (apart from oil leaks)
    Thanks!
    wirral
    56 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Easy job mate. No other real symptoms apart from obvisously the leak.
    Take ya about 20 mins to change
    Mar 2011
    Wirral
    Forgot to mention it's on a 1.9CDTi 150, I know the petrol ones are easy but is it the same with the diesel?
    Do you know if it ties in with the cambelt?
    cheers
  1. rocker cover gasket
    By SarahP in forum Engine & Drivetrain
    Last Post: 10th October 2012, 16:12
  2. 1.9 CDTI 150 - Rocker cover gasket change
    By Gavin2.6 in forum Engine & Drivetrain
    Last Post: 5th October 2012, 17:36
  3. rocker cover gasket
    By crainer85 in forum Engine & Drivetrain
    Last Post: 6th August 2012, 20:06
  4. 3,2 single or dubble rocker cover gasket
    By speedzone in forum Engine & Drivetrain
    Last Post: 3rd August 2011, 22:13
  5. Rocker cover gasket
    By stevie1 in forum Vectra C / Signum Car Chat
    Last Post: 19th May 2009, 06:48
rocker cover gasket vectra c
vectra c rocker cover gasket leak
