Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: Maf sensor
    Aug 2012
    South Wales
    Default Maf sensor
    Been having a bit of trouble with my cdti 150 and according to my dealer he reckons its the maf sensor was just woundering if there a way to clean it/service it as they want over £100 for one any ideas ?
    Jan 2012
    Milton keynes
    Trim : M Sport and Design
    Mileage : 38100
    Carb cleaner is probably your best bet.
    Regular Member john norris's Avatar
    Jun 2012
    lancashire
    carb cleaner take it off give it a good squirt but dont start rubbing cloths and tissue on it its very delicate
    wirral
    39 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Electrical contact cleaner
    Regular Member baz2003uk's Avatar
    Mar 2007
    swindon
    whats the part number on yours as i know they use the same part across allot of the engines
    i am awaiting on a new one myself should be here any time soon just hoping it cures my juddering problem
    if it doesnt i will let you know and send my old one in the post see if that sorts it out
    Regular Member viper8's Avatar
    Mar 2011
    Northamptonshire
    Baz
    does your juddering happen at high boost ?
    my signum is playing up
    and i think it is fuel related
    Mar 2007
    swindon
    na mine seem to between 1500 and 2000 rpm when in above 3rd gear if i boot it it dont happen
    viper same goes with you mate after i have swapped mine out your more than welcome to try my old one if its not faulty
    Mar 2011
    Northamptonshire
    cheers for that
    i will keep that in mind
    hope you get it sorted
    Mar 2007
    swindon
    I am hoping it is faulty as next step is coil packs all six of them £££££
    i take it yours is juddering to what rev range ect is it happening to yours
    over on vxronline it seems coil packs are popular to go on theses then chain (so hoping it not the start of the chains)
    Jun 2012
    lancashire
    wouldnt coil pack show a EML infact so would the MAF sensor
  1. Replies: 3
    Last Post: 13th August 2012, 22:25
  2. P0141-04 o2 sensor heater circuit open (bank 1 sensor 2)
    By Mark1892 in forum Engine & Drivetrain
    Last Post: 3rd August 2012, 09:19
  3. Fitting & Installation of ABS Harness & brake Help sensor sensor
    By Elahi_786 in forum Suspension, Wheels & Brakes
    Last Post: 17th April 2012, 20:46
