Results 1 to 10 of 27
Thread: Thinking of lowering...
    Regular Member Marky's Avatar
    Jun 2006
    North West
    Default Thinking of lowering...
    I have replaced the rear dampers with B4s and changed rear control arms and front drop links.
    Soon I will be putting B4s on the front.
    As the car is 7 years old and done 135k I was thinking of changing the springs (fronts are still original, rears were replaced 3 years ago).
    Now I wasnt after lowering the car but the price of a set of Pi springs with a lifetime warranty is half of what VX want for a set of SRi spings. And it's only a 15mm drop over the SRi.
    Are the Bilstein B4s ok with 30mm lowering springs?
    And do you need to do the spring sleeve mod to front lowering springs or is it only needed for VX springs???
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    The shocks will be fine with that drop, and when I fitted the PI springs on my old Vectra I fitted the sleeves on the front springs.
    Regular Member rozzer2006's Avatar
    Jun 2009
    Glasgow
    Vehicle : vectra
    Trim : VXR
    Engine : 2.8 v6 Turbo
    Mileage : 69k
    So can the car be lowered with out changing the shocks with these springs??? I dont want the ride any firmer but I want it lowered lol
    Jun 2006
    North West
    I did ask bilstein about this and they replied saying that the B4s are for standard springs. However they knwo people have added lowering springs with no problems but don't recommend it.
    On here people have said that you should be ok for 30mm lowering springs (the SRi springs are already 15mm lower than standard).
    Any lower and you need sports dampers that are specifically for lowering springs.
    Not done mine yet, waiting for some money and need to decide to go for Pi or Eibach.
    Jun 2009
    Glasgow
    Vehicle : vectra
    Trim : VXR
    Mileage : 69k
    yeah its ovb the travel of the dampers, so 30 mm springs should be ok u recon?? that would be fine anyway my sri rides quite low anyway
    Regular Member 19CDTi's Avatar
    Jul 2009
    Perth, Scotland
    Seen discussions on here stating standard shocks are ok til 40mm. Not done it meself so can anyone confirm or otherwise?
    HTH
    Stuart
    Lancashire
    Trim : XP1
    Mileage : 66000
    Quote Originally Posted by 19CDTi View Post
    HTH
    Stuart
    I had PI 45/40 on my old Vectra SRi with standard shocks and had no issues what so ever, so I would say SRi shocks ok, wouldn't be too confident on non-sri shocks though.
    Jul 2009
    Perth, Scotland
    Interesting note there Dan, thanks.
    Mine are above SRi so think I might just get away with standard shocks on 35mm
    Sorry for the hijack
    Stuart
    Jun 2009
    Glasgow
    Vehicle : vectra
    Trim : VXR
    Mileage : 69k
    sorry marky i just read that back sounded a bit cheaky lol,
    i might go for the 40's then, r u sure dan lol the springs didnt go lose due to the travel of the shocks when u jack it up??
    sounds to good to be true lol.
    cheers
    Quote Originally Posted by Marky View Post
    Ex-Staff Full Member Spelly's Avatar
    Derbyshire
    6 Post(s)
    Ive done this several times on Sri / Gsi Vec C's. You will be fine with a 40mm drop on the Sri shocks as long as they are in good working order. Its 40mm from standard height so will actually be a 25mm drop on an Sri. Just ensure that you get the correct springs that are matched to your axle weights (on a plate inside the drivers door B pillar) as some models require different spring rates. Ive always used Eibach and found them to be an excellent balance between ride and performance
  1. Thinking Big, Thinking Transplant
    By paddyvectra in forum Diesel Engine related
    Last Post: 14th August 2011, 20:41
  2. Thinking about getting lowering springs & ...
    By Mark2.2 in forum Suspension, Wheels & Brakes
    Last Post: 21st February 2010, 10:02
  3. Would I be right in thinking....
    By Dan_BlackSRi in forum Diesel Engine related
    Last Post: 29th January 2009, 18:09
  4. Thinking of lowering mine??
    By mitch1965 in forum Handling & Braking
    Last Post: 31st July 2008, 21:04
  5. Thinking About
    By don paul in forum Styling
    Last Post: 29th March 2008, 11:20
