Results 1 to 10 of 20
Thread: New rs tuning results
    Regular Member Elahi_786's Avatar
    Oct 2010
    Bedford
    Talking New rs tuning results
    Just an Update for all. New Mods - Water Methanol + Injector flow increased 19% Calibrated and balanced flow rate.
    WATER METH DOES INCREASE POWER + TORQUE THE TWO GO HAND IN HAND.
    More power to come from a few more mods, Bigger MAF / Bigger water Meth Nozzle
    255 BHP / 380 TORQUE WITH WATER METH
    WITHOUT WATER METH 246.6
    YOU COULD SAY THE EXTRA FLOW CONTRIBUTED TO 6 BHP AND THE REST BY WATER METH
    May 2011
    Ashby-de-la-Zouch
    Trim : sri nav/Elite
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    nice results but why does the torque dip between 2800 and 3200?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Impressive m8 but I have to say as much as Harvey smith has proved how far this engine can be pushed, my limits are larger turbo, larger intercooler and remap to get to 220bhp I'd be happy.
    Oct 2010
    Bedford
    I believe the clutch is slipping and is getting worse on the stock DMF.
    THIS is being sorted as we speak and the car should be able to put the power down a lot better with an uprated clutch and single mass flywheel.
    Oct 2010
    Bedford
    GAZ from what I have learnt you can get those gains quite easy as long as you have the right size turbo and a good intercooler which preforms its duty.
    morecambe
    37 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Top lad is Harvey Wich reminds me need to speak to him graph looks about spot on fella nice clean lines
    May 2011
    Ashby-de-la-Zouch
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    that's brave putting a single mass flywheel on lol
    morecambe
    37 Post(s)
    Vehicle : vectra
    Trim : vxr
    Not really dan alot down here are welding them up now lmao get ya self a 6 paddle clutch in it fella
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by Elahi_786 View Post
    Cheers was thinking of a 52mm wheel by the looks of things. Got a turbo un the boot of the car waiting to be worked on.
    Quote Originally Posted by dan danz View Post
    The DMF should last of the gears are used properly (not jumping into higher gear than is needed) and starting the engine with the clutch pressed. Solid flywheels will allow the teeth of the gears to rub under dangerous harmonics and subsequently break possibly.
    May 2011
    Ashby-de-la-Zouch
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    Quote Originally Posted by paulvectrac View Post
    i might do this if mine started rattling but don't they break crank shafts and gearboxes? and dmf are smoother and grip better. and wont welding the dmf make it unstable and cause more vibrations than smf?
  1. My Day at Rs Tuning ! Happy Results
    By Elahi_786 in forum Diesel Engine related
    Last Post: 17th July 2012, 20:33
  2. Results for RR 27th Feb 2011 at Redline Tuning
    By plasma in forum East (RO - WhiskyNo7, ARO - Plasma)
    Last Post: 28th April 2011, 12:55
  3. rr results
    By gav_embo in forum Diesel Engine related
    Last Post: 25th October 2009, 16:51
  4. here are the results
    By Grimo72 in forum Vectra C / Signum Car Chat
    Last Post: 1st June 2008, 21:26
  5. Bhp Results
    By armoured farmer in forum Vectra C / Signum Car Chat
    Last Post: 1st March 2006, 11:18
