Thread: Hot rear n/s wheel
    Sep 2012
    england
    Default Hot rear n/s wheel
    Just having recently purchased my Vectra C 1.9 CDTI 2006, I have noticed a burning smell and a very hot hub on rear n/s wheel. Have taken vehicle back to seller on 3 occasions having now replaced the calliper, brake flex-hose and also rear wheel bearing hub but to my dismay I still have the same problem with the wheel getting far hotter than the off-side. Only thing we haven't done is check wheel alignment. Can anybody help in diagnosing any other problems we may not have thought of that are causing the problem. All brakes have been checked and don't appear to be sticking, and periodically along with the very hot wheel, I also get a high-pitched whine from the same wheel.
    Regular Member Knight Rider's Avatar
    Apr 2008
    Motherwell
    Vehicle : Vectra C SRi 1.8vvti
    Trim : Sri
    Engine : 18.vvti
    Mileage : 29,500
    Pads sticking?
    Sep 2012
    england
    Not that I am aware of, as these have been checked.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Have they replaced the cable? It may be sticking in the tube
    Sep 2012
    england
    No cables have been replaced but having had so many people look at the problem, would have thought someone would have picked up on it. Are you referring to the hand-brake cable?
    Regular Member MattVecVXR's Avatar
    Mar 2012
    Torpoint, Cornwall
    Trim : VXR
    Engine : 2.8 V6 Turbo (280)
    Mileage : 82000
    Have you had the rear discs replaced? If that disc is slightly warped it will cause rubbing leading to high temperatures.
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Quote Originally Posted by edavidgel View Post
    Yep
    Sep 2012
    england
    No discs have been changed as yet. Someone did mention that I would notice if the discs were warped because the brake pedal would judder/vibrate???? Not sure how true this is?
    Mar 2012
    Torpoint, Cornwall
    Trim : VXR
    Mileage : 82000
    If it was the front it would be much more noticeable but a slight deflection can cause all the symptoms you've mentioned but be masked by the fact that its a smaller rear disc. is there any bluing on the disc, signs of overheating?
    Regular Member Neve'o's Avatar
    Norfolk
    Vehicle : Vectra SRi 150 Hatch
    Mileage : 69'000
    on the rear the juddering would be felt though the actual car and seats, not the pedal.
    I would jack the offending corner up so the wheel can spin freely, then turn it by hand and listen/feel for any points in which the pads binds with the disc, if its a warped disc and the problem is bad enough you should be able to hear/feel this.
    Also does this wheel end up with more brake dust on it than the other side? I have always found a sticking calliper to leave loads of brake dust due to the binding and if left long enough the pads should be more worn than the other opposite wheel
  1. My rear wheel
    Last Post: 27th May 2012, 13:19
  2. Rear wheel droaning
    By Telboy in forum Suspension, Wheels & Brakes
    Last Post: 22nd December 2011, 14:15
  3. rear wheel hub
    By geebee007 in forum Suspension, Wheels & Brakes
    Last Post: 14th March 2011, 02:25
  4. rear wheel wobble
    By niicckk in forum Suspension, Wheels & Brakes
    Last Post: 19th June 2010, 12:48
  5. play in rear wheel
    By micks edition 100 in forum Suspension, Wheels & Brakes
    Last Post: 18th November 2009, 21:31
