Results 1 to 3 of 3
Thread: does the engine managemant light have to be on to have a fault code.
    Regular Member davedave's Avatar
    Apr 2012
    manchester
    Default does the engine managemant light have to be on to have a fault code.
    hi people
    i think i might have a fault code , but i was wondering does the engine managemant light have to be on to have a fault
    cheers
    Essex
    Fault only active if engine management light is on when the engine is running.
    If its on when the ignition is on then there is an old fault stored that isn't causing problems anymore.
    Apr 2012
    manchester
    my vectra turbo keeps idling up and down and then very low when i slow the car down , and now its started cutting out when i slow the car right down , any ides anyone
  1. engine fault code po305
    By gspot10 in forum Electrical & ICE (including SatNav)
    Last Post: 10th April 2010, 12:37
  2. Emissions Light - Fault Code Help!!!
    By Stu_2010 in forum Engine & Drivetrain
    Last Post: 4th January 2010, 23:48
  3. Engine fault code reset
    By papz in forum Vectra C / Signum Troubleshooting
    Last Post: 21st June 2009, 18:44
  4. Engine Fault Code
    By VECTRAMAN in forum Vectra C / Signum Car Chat
    Last Post: 5th November 2008, 18:34
  5. ECU Light & Fault Code help!
    By petesaysblimey in forum Engine & Drivetrain
    Last Post: 24th September 2008, 15:03
