Thread: HELP! cleaned EGR now have fault p2279
    hull
    Default HELP! cleaned EGR now have fault p2279
    Hi all, as title i thought i would take my egr off today to clean to see if i could get rid of the smoking and lack of low end power my car has cdti 120. Cleaned it and put back together and now runs terrible, no power at all, turbo not kicking in either, smoking real bad, eml on showing code p2279. Checked all connections etc all nice and tight, what next??
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 138000
    this may help but i read somewhere someone did not plug the egr lead in enough
    and make sure tha gasket in lined up
    http://www.vectra-c.com/forum/showth...ult-code-P2279
    hull
    Quote Originally Posted by vectra ste View Post
    cheers for the link mate, i didn't clean and dismantle the solenoid side so i guess thats my next job
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 138000
    Quote Originally Posted by frasedeb View Post
    yes thats in post 8
    hope all goes well
    and the rain keeps off
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 138000
    keep us updated
    hull
    Update on my problem, opened the solenoid side of the egr by removing the 4 torx bolts and couldn't beleive how much soot was in it. It was completely full to the top with soot so dug it all out and cleaned with inlet/carb cleaner, the black plastic part of the egr was ok and the solenoid moved freely so just squirted a bit of wd40 0n the solenoid and worked it up and down.
    Put it all back together and WOW! it's a different car, effortless power,smooth pickup throughout and hardly any smoke unless i really boot it.
    At least i know what to do next time thanks to vec-c.com.
    cheers.
    Aug 2012
    South Wales
    Would a stick Open egr cause problems even though it blanked by playing the ecu up
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 138000
    cheers.
    glad to help mate
  1. P2279 fault when egr mapped out.
    By mally in forum Engine & Drivetrain
    Last Post: 11th November 2012, 16:16
  2. Fault code P2279?
    By Phil MC in forum Engine & Drivetrain
    Last Post: 8th July 2012, 19:29
  3. 1.9 CDTI fault code P2279-11
    By mozzer99 in forum Engine & Drivetrain
    Last Post: 14th June 2011, 20:13
  4. fault code p2279
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 20th November 2010, 20:14
  5. Fault code P2279 Showing.HELP!!!.Info PLEASE.
    By felixx in forum Engine & Drivetrain
    Last Post: 28th October 2010, 18:34
