Thread: Z19DTH not starting
    Sep 2011
    West Mids
    Default Z19DTH not starting
    A mate of mine has a 150 bhp 16v vectra and Saturday he broke down. Symptoms were and increase in temp to 100 deg. and a rattle from the engine with a burning/electrical smell from the back of the engine bay just after it died. I said it sounds like water pump failure. Having checked the timing belt yesterday it is intact and doesn't appear damaged but the car won't start and it keeps throwing a P0340-28 camshaft sensor range/performance code on my reader. As the water pump runs on the non-toothed side of the belt is it possible for it to cause any timing/jumped tooth issues when they cease? or does anyone have any ideas as to what the issue may be?
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 139000
    this may help
    sounds like the waterpump has seized
    http://www.vectra-c.com/forum/showth...6v-CDTi-owners
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 139000
    Sep 2011
    West Mids
    Update:
    Picked it up from the garage last night and the belt guide had gone. So new guide, belt and water pump etc.. but the car has no low down power, kicks out more black smoke than any car I've ever seen and is a ***** to start. Mechanic is saying it has taken a valve and wants £900 to sort it. The belt didn't break but jump when the guide collapsed so could have taken a valve as the engine ran on for a while but would it also result in black some belching from the exhaust? It is also giving a P2279-5b fault code if that help
    May 2006
    scotland
    As I believe it, these engines can take valves out but more likely that they break the rockers instead. I would suggest somone look in the engine top end to see if any visible damage
    Sep 2011
    West Mids
    that was checked when the cam belt was done and none of the rockers were damaged but thanks for the suggestion.
    Regular Member C-Owner's Avatar
    May 2011
    South London
    Quote Originally Posted by bert3d View Post
    Update:
    Personally I would make sure its been put back together correctly.
    Sounds like the mechanic may have left a pipe off some where.
    Check all induction and exhaust including EGR for air leaks.
  1. Not starting..... Possible Starting Motor
    By portreathbeach in forum Vectra C / Signum Troubleshooting
    Last Post: 25th August 2012, 11:30
  2. Oil for z19dth
    By neill in forum Engine & Drivetrain
    Last Post: 18th July 2011, 18:45
  3. z19dth
    Last Post: 22nd April 2011, 08:38
  4. EML flashing when starting but not starting (Vec-B)!
    By Vaux-Man-G in forum Engine & Drivetrain
    Last Post: 29th July 2009, 15:51
  5. z19dth
    By taralko in forum Vectra C / Signum Troubleshooting
    Last Post: 1st July 2006, 13:36
z19dth not starting
vectra z19dth no start
vectra z19dth p0340 camshaft sensor
z19dth wont start
Vectra z19dth crank no start
vauxhall fault code p2279 5b www.vectra-c.com
z19dth p0340
z19dth p0340 0015
