Thread: No boost under 2k
    Aug 2012
    South Wales
    Default No boost under 2k
    Having no boost under 2k for a while with poor fuel consumption this is what's been done so far
    full service
    new inlet manifold and egr
    cleaned boost sensor
    new pipes on boost control solenoid
    new thermostat (know wont cause boost problems bus was broke)
    egr blanking plate
    was woundering if anyone has any ideas why the problems are still car runs fine otherwise any help would be great
    Aug 2012
    South Wales
    Sorry it's a 1.9 cdti Sri 150 with 80k on the clock
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 141000
    Aug 2012
    South Wales
    Done all that the only thing I not done is strip and clean the boost control solenoid and the throttle housing
    Aug 2012
    South Wales
    [QUOTE=Mike1975;1886332]Having no boost under 2k for a while with poor fuel consumption this is what's been done so far
    full service
    new thermostat (know wont cause boost problems but was broke)
    egr blanking plate
    Update on problem
    stripped and cleaned throttle body housing and checked and cleaned circuitry all fine but housing well full of gunk
    stripped and cleaned boost control solenoid that all sorted and working tidy now was also gunked up
    replaced injectors 3 and 4 wiring cconnections
    it ticks over much smother now and there n judder around the 1400 mark the problem of no boost under 2 k is still there but now noticed a lot more boost above think the bcs was so dirty that it wasn't boosting tidy I also reset the service light gone out now but on start up the car spanner light is on till you give a tap on the throttle (is this right) also noticed a bit of a whine now when the turbo kicks in can anyone help
    would also like to say a big thanks to all on here because the work I have done sor far on it the help 2s and people's comments have saved me a fortune thanks all
    Aug 2012
    South Wales
    Can anyone help ?
    Jan 2012
    Gloucestershire
    When you say "tap the throttle", do you mean enough to raise the revs above 1500rpm (turbo kicking in) or not?
    Turbo whining may be a sign you have got something working that wasn't before - the bcs controls the turbo wastegate so maybe this is functioning properly now.
    Aug 2012
    South Wales
    I mean just tap it so the rpm bearly go up and that what I thought bout the bcs and there more power there now to but still can't get any below 2 k and then when it kicks in it so sharp that it make I wheel spin upto 3rd it not smooth at all just bang there it is
  1. No Boost/Irregular Boost
    By Seery_SRI in forum Engine & Drivetrain
    Last Post: 8th March 2011, 08:48
  2. boost flat spot boost????
    By lgtuk in forum Engine & Drivetrain
    Last Post: 7th June 2010, 16:14
  3. CDTI 150, 10k Boost De-Coked & New Boost Sensor
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 4th January 2010, 12:02
  4. no power off boost then savage boost at 2300rpm
    By 9tjc in forum Engine & Drivetrain
    Last Post: 2nd January 2010, 00:21
  5. cleaned boost sensor and still shows over boost
    By chowwie in forum Engine & Drivetrain
    Last Post: 14th November 2008, 09:23
