Results 1 to 10 of 25
Thread: Cruise Control not working
    Dec 2011
    Yorkshire
    Default Cruise Control not working
    My cruise control on my 3.2 Auto seems to work intermittently.
    It may work the first time I use it, but then if I turn it off or brake, the cruise disengages (as it should) but then will not re-engage.
    Any suggestions on what I could look at please?
    Thanks.
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Take the indicator arm out and clean the contacts as the cheapest and easiest thing first. Then try lifting the clutch pedal with your foot when on them move, if this helps replace the switch on clutch pedal, cheap and easy to replace.
    Regular Member 19CDTi's Avatar
    Jul 2009
    Perth, Scotland
    Hey guys, sorry for the part-hijack. I'm looking to do this on mine tonight. Is it easier to take off the boot from the steering wheel end or the stalk end of the "booted" area?
    Stuart
    Jul 2010
    Shropshire
    The boot on the stalk just pops out at the steering wheel end. Then on the back of the stalk there is a hole/chanal where you shove a piece of stiff wire down. Pushing the wire down there makes the stalk pop out. Hope that helps.
    Dec 2011
    Yorkshire
    Thanks, except that I dont have a clutch as my car is an auto lol.
    Jul 2010
    Shropshire
    Unlikey to be the problem then! There will be a switch on the brake, worth checking but not common for the one on the brake to go.
    Jul 2009
    Perth, Scotland
    Quote Originally Posted by andy83 View Post
    Cheers Andy, it does indeed!
    Stuart
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Quote Originally Posted by VeccyMike View Post
    Doh, so you do, lol.
    As Andy says next port of call would be the brake switch too, after that well lest hope its not a CIM problem as thats where it gets expensive.
    Dec 2011
    Yorkshire
    whats the CIM?
    If I turn the car off and re-start it then it works again for a short while.
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    CIM=Column Interface Module. It sits behind the steering wheel, where the indicator and wiper stalks attach too, part of the canbus system, lets not hope its that because from the dealer you'll be looking at £250+
  1. cruise control not working
    By bigsteve3.0v6 in forum Electrical & ICE (including SatNav)
    Last Post: 9th October 2011, 21:53
  2. Cruise Control not working :(
    By Princess D in forum Vectra C / Signum Troubleshooting
    Last Post: 14th January 2011, 16:16
  3. Cruise Control - working again!!?
    By djr69uk in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2009, 19:30
  4. Cruise Control not working
    By jonnyc in forum Electrical & ICE (including SatNav)
    Last Post: 21st December 2007, 04:53
  5. Cruise control not working
    By armoured farmer in forum Vectra C / Signum Car Chat
    Last Post: 6th August 2006, 21:07
