Thread: Passenger heated seat not heating
    Dec 2011
    Yorkshire
    Default Passenger heated seat not heating
    The heated seat on my Elite has stopped getting hot.
    The switch appears to work (yellow light comes on when switch is set to 1+).
    I'm going to check the connections, but realistically, is there anything else that it could be? The drivers side one works fine.
    Thanks.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Loose/poor connection
    No power/ ground going to it
    Heat element damaged
    Dec 2011
    Yorkshire
    Thanks..
    What could cause the element to be damaged? The car hasnt been used much over the last year..
    Thanks.
    Dec 2011
    Seaham
    Also check fuse to seat relay and the relay itself. You may have power going to the switch and away from the switch, but the switch will not carry the power to the element.
    is there a pressure switch on the seat? i.e. it has to be occupied for it to work?
    Regular Member dilan's Avatar
    Aug 2009
    dudley, west midlands
    Sorry to hijack folks but my drivers side doesn't work either,, switch lights up etc but no heat.... Where are the relays located for them.....
    Sent from my iPhone using Forum Runner
    May 2011
    Ashby-de-la-Zouch
    Trim : sri nav/Elite
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    that's funny because my driver seat don't work ether the switch lights up. they don't have pressure pads.
    Dec 2011
    Yorkshire
    Thanks, I'll check the fuse and relay, didnt realise there was a relay so could well be this.
    Dec 2011
    Yorkshire
    Does anyone know where the fuse and the relay are located?
    Nov 2010
    Maidstone
    Im not so sure dan, my leather wont heat up unless seat occupancy sensor is activated which would suggest it does work from pressure switch.
    Jun 2009
    South Coast
    8 Post(s)
    Vehicle : Signum & Insignia
    Engine : POS derv
    I am sure they are black relays in the rear fusebox. One for fronts and one for rears (if you have them).
  1. Heated seat drivers backrest not heating?
    By ronnie63 in forum Bodywork & Interior
    Last Post: 4th December 2012, 14:30
  2. heated seat switches? also electric seat adjust questions?
    By big rich in forum Vectra C / Signum Car Chat
    Last Post: 26th November 2010, 11:48
  3. FOR SALE: Heated seat switch passenger side
    By merikiito in forum Parts for sale
    Last Post: 12th November 2008, 11:11
  4. Heated mirror not heating up.
    By stevegreg in forum Electrical & ICE (including SatNav)
    Last Post: 18th January 2008, 00:59
renault scenic heated seat relays
vec c heated seats lights on but no heat
vectra c heated seat switches light up but no heat
