Thread: sqeal from pump 3.2 v6
    Mar 2011
    wilts
    Default sqeal from pump 3.2 v6
    just got back from a 70 mile round trip and have now noticed a squeel from the left hand side ( looking under the bonnet) . could it be waterpump or air con pump bearings?
    only just started today didnt use it yesterday, but had a/c on today.
    New Member Stuart7111's Avatar
    Sep 2012
    Brisbane, Australia
    I have the same issue I think. My guess is the tension pulley needs replacing, but I can't be sure. It's usually there when I start up the engine. It will stop for a bit and come back when I accelerate. I hear the noise better when driving with the window down. Only problem I can't 100% determine if it is the tensioner pulley or something inside around the timing belt system. Also looking for how to repair this if a manual exists for the 3.2L V6 (Built Oct'03). Any advice would be great!
    Dec 2011
    Seaham
    Try a couple of squirts of WD40, see if it goes away? If its a dry bearing the squeel should go away until the WD40 dries off.
    Mar 2011
    wilts
    problem was water pump bearing. pricey around £120 but vauxhall parts garuntee covers faults and labour unlike aftermarket which was £30 cheaper
  1. Possible Vac pump?
    By lenny-mik in forum Engine & Drivetrain
    Last Post: 10th May 2012, 16:03
  2. away to pump 500L of heating oil with a 3.99 ebay drill pump.
    By TimTay in forum The 'Off Topic' room
    Last Post: 19th September 2011, 22:09
  3. HELP!!! oil pump
    By Awkward kid in forum Engine & Drivetrain
    Last Post: 30th January 2011, 20:05
  4. 10 Pump BB Gun
    By 21_03_sxi in forum Comedy & Humour
    Last Post: 17th January 2008, 00:47
