Thread: dmf change
    Sep 2012
    Middlesbrough
    Default dmf change
    has anybody changed a vectra 1.9cdti dmf without completely removing transmission? i realise space will extremely tight but if it can be done there would be no issues with subframe re alignment. cheers
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    I have done a couple of these at work & always removed the gearbox completely , it would be a nightmare to try & do it with the box moved to one side or whatever .
    Sep 2012
    Middlesbrough
    thanks dti elite, thats what we decided to do. just hope subframe alignment is ok.
    Sep 2012
    Middlesbrough
    Did the job on my drive, only took 4 days . Car runs great! cost me around £500 for LUK clutch and slave cylinder, Sachs DMF, 2.4 litres of GM gearbox oil and new nuts and bolts. The clutch plate and release bearing looked in good condition but it made sense to renew the lot. I don't fancy undertaking this job again. I shall be driving like a vicar from now on!
    Slough
    90 Post(s)
    Vehicle : insignia vxr
    Trim : vxr
    Engine : 2.8 turbo
    Year : 61
    Mileage : 38000
    just had mine changed , the mechanic took around 3 hours to do it .the car feels so much better again . he did say to have the alignment checked , which ill do in the morning .
    the vectra has gone , but not far away so ill still see it form time to time
    Sep 2012
    Middlesbrough
    Quote Originally Posted by happypostie View Post
    How much did that cost ya? I got quoted £650 but it was using Motorquip parts.
    Slough
    90 Post(s)
    Trim : vxr
    Engine : 2.8 turbo
    Year : 61
    Mileage : 38000
    Quote Originally Posted by Milliedog View Post
    using all vx parts ( as wanted there warranty which incs labour ) was 700 all in inc a oil/filter change as well .
    Sep 2012
    Middlesbrough
    Its just finding a mechanic you can trust. My last car (Rover 200) I put it into a garage as the clutch pedal was really stiff, he said he changed the clutch but a few months later it happened again, A few squirts with wd40 sorted it out. I suspect I paid my £180 for nothing . I wonder how many mechanics would just put the old clutch and cylinder back in. At least doing it myself I have saved at least £150 and I have piece of mind that it has all been changed. I plan to sell my old clutch and cylinder on ebay too.
    May 2012
    county durham
    Mileage : 145k
    did mine on wednesday night at work , 2 post lift , engine support beam & gearbox jack etc all to hand .
    needed new inner boots on the driveshafts & a drop link was looking a bit worn so did the lot while I was on with it .
    really wouldn't like to be doing one on the floor .
  1. Automatic Gearbox Oil - Change Or Not Change?
    By rocket999 in forum Engine & Drivetrain
    Last Post: 24th May 2013, 17:50
  2. Manifold change poll: Actuator change or not
    By hertscol in forum Vectra C / Signum Car Chat
    Last Post: 22nd May 2012, 18:52
  3. Oil Change
    Last Post: 22nd March 2012, 10:45
  4. Change Discs - Change pads?!?!
    By Leemarksmith in forum Suspension, Wheels & Brakes
    Last Post: 11th April 2010, 09:54
