Thread: Replace 2.2DTI intercooler pipes?
    Apr 2008
    manchester
    Default Replace 2.2DTI intercooler pipes?
    Good evening all, I have split in my LH intercooler pipe so I'm going to replace it, however I'm wondering if I should just bite the bullet and replace all of them, I have seen some blue ones on line, that will replace the one I need, but I would like to buy a full set if possible as I imagine it would work out cheaper to get them all in one go
    anyone done this? Or know where I can get a set from?
    VIP-Member Z80's Avatar
    Apr 2008
    Noumea
    12 Post(s)
    Vehicle : Opel Vectra GTS
    Trim : Elegance
    Engine : 2.2 DTi 16V
    Mileage : 75 000
    Hi !
    You have to replace them with silicone ones if you don't want to blow them up again within two years. A lot of oil comes from the cranckase into the intake, and it destroys the original rubber ones in no time, so sticking to GM hoses will trigger the problem again and again.
    Gloss black :
    http://www.ebay.co.uk/itm/Vauxhall-V...item43ada69e51
    Blue :
    http://www.ebay.co.uk/itm/Vauxhall-V...item45fdb1f47c
    Red :
    http://www.ebay.co.uk/itm/Vauxhall-V...item43aa97b628
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    As above with the links and info from Z80 , currently the two lower ones the 180 degree bends are not available but plans are afoot to source a manufacturer
    and still loving it
    Apr 2008
    Noumea
    12 Post(s)
    Trim : Elegance
    Mileage : 75 000
    Actually, this provider also has a 5 hoses set for 1.9 CDTi including the bottom ones.
    He agreed to make me a special mxed set including the two top DTi hoses and two bottom CDTi hoses.
    I didn't fit them yet (waiting to finish my xenon + angel eyes Frankenstein assembly), but they should be similar enough to fit (I'd probably have to shorten one of them).
    Since I'll have to put the bumber down either for the headlights and the bottom hoses, I'll do all at the same time. I also have to clean up my EGR valve I suspect to stay half open, judging by the soot that deposits on the hatch and the limp mode that triggered twice one day a few weaks ago (it may also be some small turbo hose or vacuum pipe leak).
    Oct 2009
    wallacestone
    Hi,
    If you do find a source dor the intercooler bottom hoses, be much appreciated as have had to replace the top hoses with silicon ones, goes like a new car now.
  1. Intercooler pipes.
    By dazza2393 in forum Engine & Drivetrain
    Last Post: 23rd September 2012, 08:59
  2. Oil misting in intercooler pipes....
    By martyngell in forum Y & Z30DT Specific
    Last Post: 24th February 2012, 23:41
  3. oil intercooler best place to get replacement pipes from
    By bert01909 in forum Engine & Drivetrain
    Last Post: 19th September 2011, 18:38
  4. 2.2 dti intercooler pipes
    By peadar in forum Diesel Engine related
    Last Post: 3rd March 2011, 21:57
  5. 2.0dti intercooler pipes collapses!
    By ricky1 in forum Vectra C / Signum Car Chat
    Last Post: 8th October 2010, 18:22
z30dt intercooler pipe
intercooler pipe 2.2 dti
how to replace intercooler on opel vectra c
vauxall 2.2 dti intercooler pipe replacement
