Results 1 to 10 of 14
Thread: Gear Box Oil Level??
    Sutton Coldfield
    Vehicle : Siggy Sports Tourer
    Trim : SE - But fully loaded!
    Engine : 160 cdti
    Default Gear Box Oil Level??
    Besides draining the gearbox on my cdti 150 06 estate and refilling it with the correct amount of oil, is there a quick way to check the level is sufficient from the top??
    Stuck a screwdriver in through the filler and didnt touch the oil??
    Aug 2012
    usually the oil is the correct level if it is level with the filler hole. But to be honest I am running on experience from BMW's so not 100% and am open to correction
    Mar 2011
    belfast
    The only way to be sure you have the right level is to fill it until the gear oil comes back out of the filler hole,
    Really easy.
    Sutton Coldfield
    Engine : 160 cdti
    Needs another litre of oil then!!
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Woah! before the OP over fills his gearbox to the max there is no level check hole on an f40 box.
    The filler hole is just that....a filler hole. The only way to know how much oil is in the box is to drop the oil and refill with the correct amount unfortunately. It's only a fiver or so a litre from VX though
    The revised oil level to reduce notchy changes on the f40 is 2.4 litres as opposed to the original 3.2
    Regular Member Wy1717e's Avatar
    Jun 2012
    Banbury
    Hi sorry to sound stupid but where is the gearbox oil filler hole I have a vectra. 1.9 cdti sri 2005
    South east
    Quote Originally Posted by Wy1717e View Post
    Read the How To threads for the F40 gearbox.
    Regular Member SarahP's Avatar
    Nov 2011
    Buckinghamshire
    i didnt know the gear box had oil!!
    Dec 2011
    Seaham
    Erm yep, but you do not normally do any routine maintenance on it unless there is a leak or you have completed very high mileage.
    South east
    Quote Originally Posted by SarahP View Post
    Any machine that has moving metal parts that make contact with other metal parts needs oil.
  1. cdti stiff gear change, removing gear turret?
    By IrishVectra in forum Vectra C / Signum Car Chat
    Last Post: 18th December 2016, 16:15
  2. Reverse gear - weak spring on gear stick
    By Dal5band in forum Bodywork & Interior
    Last Post: 20th December 2011, 13:18
  3. Help how do i check my auto gear box level?
    By lukesignum in forum Engine & Drivetrain
    Last Post: 1st September 2010, 20:47
  4. Stiff gear change, gear selection fine though
    By tramman in forum Engine & Drivetrain
    Last Post: 24th November 2009, 23:20
  5. Vec C 52 plate 2.2 Dti Gear Stick Jumps out of 1st gear on take off
    By ukwanderer01 in forum Engine & Drivetrain
    Last Post: 5th July 2009, 21:43
1.9 cdti signum gearbox oil level
opel 1.9 cdti F40 gearbox oil level
