Thread: bizzare clicking sound upon starting
    Nov 2010
    luton
    Default bizzare clicking sound upon starting
    Hi, the missus has just alerted me to some strange clicking sound that has developed this week, im running a 2004 1.9 CDTI 150 estate
    About 2 seconds after starting there is 4-5 loud clicks that appear to be coming from under the passengers side dash
    If I turn the key onto glow plugs and dont start the engine the same noise is made
    car starts fine, drives fine and no spanner lights etc. I now something is about to go but what ?
    Have you guys any idea ?
    Mike
    Dec 2011
    Seaham
    Are there any relays situated there?
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Air recirc flap motor unit has broken a tooth, got exactly the same on mine at the moment, it's a common fault.
    Turn your ignition on, press the recirc on, leave for a few secs and switch the recirc back off again, does it make the clicking? If so, that's what it is. The motor is just behind the glovebox on the right, connected to the main air box.
    The air direction one can go as well so if it doesn't do it on the recirc switch on and off, see if it does it with different positions on the air direction selector.
    Nov 2010
    luton
    thanks Ian, i'll try that the morrow ,
    Ely, Cambridgeshire
    61 Post(s)
    Year : 2010
    Bad news is that if it is that which has gone, it's £72 from the dealers to replace. I decided to put up with the clicking on mine for now
    Nov 2010
    luton
    tried it, yes, sounds about right !!!!! recirc makes it go away but it returns when off, also when i change the temp dial from cold to hot it clicks too
    Is this something that I need to replace or can it be lived with as im looking at trading in the veccy in 2 years , if not, is this easy enough to replace with a moderate level of diy skills or will it be an expensive book in to a garage ?
    thanks, Mike
    Ely, Cambridgeshire
    61 Post(s)
    Year : 2010
    Sounds like they've both gone then fella. They're simple enough to change, they're behind the glove box (which is just 5 torx screws to remove).
    Nov 2010
    luton
    ahh ****** !!!! , ok thanks Ian
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 136000
  1. strange clicking sound?
    By daddy5times in forum Bodywork & Interior
    Last Post: 12th August 2014, 20:10
  2. Clicking sound when pushing on clutch
    By TonyTangles in forum Vectra C / Signum Troubleshooting
    Last Post: 12th April 2011, 22:25
  3. Unlocking vectra- clicking sound
    By cribby in forum Vectra C / Signum Car Chat
    Last Post: 6th June 2010, 23:12
  4. clicking sound on unlock
    By big_dave in forum Electrical & ICE (including SatNav)
    Last Post: 2nd March 2009, 17:28
  5. clicking sound & anti roll bars
    By ozzye in forum Suspension, Wheels & Brakes
    Last Post: 4th April 2007, 15:07
