Results 1 to 10 of 17
Thread: Damaged lacquer. One for the paint experts!
    Sep 2010
    north east uk
    Default Damaged lacquer. One for the paint experts!
    I have been removing some swirl marks that could only be seen in certain light conditions. Unfortunately, i rubbed a bit too hard on a couple of areas & seems like i have damaged the clear coat around the filler flap & tailgate rear edge.
    Any ideas of a cheap fix, or to make it look less rubbish without getting the panels resprayed?
    Many thanks.
    Regular Member 19CDTi's Avatar
    Jul 2009
    Perth, Scotland
    That looks really odd. Has the car been repainted or relacquered as far as you know? Also what were you using to remove the swirl marks?
    I'd wager that a coat of decent wax might soften the blow?
    HTH
    Stuart
    East Midlands - Regional Organiser new boy's Avatar
    Nov 2010
    lincs
    79 Post(s)
    Vehicle : Design
    Trim : SRI LEATHER
    Engine : 1.9 cdti
    Year : 56
    Youve gone through the laquer the only to get rid is to have panels painted again. If you try to polish to will only go down to the basecoat and look even worse.
    Woodbridge
    Yep as above, that is a little surprising though, would be interested to hear what you were using.
    This has happened by hand, so polishing with a DA cant always be assumed as safe. Paint thickness has to be taken in to consideration.
    Do you know if your car has been machine polished before?
    Hanging Heaton
    23 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    You could possibly fix that with a cheap rattle can of lacquer... Bob it on lightly and flat it back once dry as long as there's enough colour coat left...
    Oct 2006
    North Yorkshire
    Vehicle : Astra
    Trim : GTC VXR
    Engine : 2.0 Turbo Petrol
    Year : 2015
    Mileage : 3,200
    Think repainting will be the only way to put it right tbh, you must of been rubbing hard with a very abrasive compound?
    Engine : 1.9 CDTi
    Looks like its been machine polished (Not with a DA) or its had a smart repair done in the past.
    Sep 2010
    north east uk
    Thanks for the replies. I first tried meguairs scratch X to try to reduce the swirl marks....i thought it had done the job untill the sun was in a certain position & it looked just as bad. The stuff that did the damage was mer scratch paste, my fault for rubbing too hard on the tailgate edge.
    I bought some meguiars ultimate compound & done the whole car with it....seems good stuff & finished off with some autoglym SRP. The car looks really good now apart from the damage to the lacquer that i inflicted on it
    Dont know if it has been machine polished in the past & i dont see any obvious evidence of any paint repairs\resprays ever been done. I took it to a local repair place today & he confirmed that the panels will need respraying to correct the damage.
    Anyway, i have learned a valuable lesson, dont use aggressive paste unless you know what your doing & dont rub too b****y hard!
    Ps, just a thought, wonder if a rear spoiler would hide the damage on the tailgate?
    Many thanks again to all.
    Regular Member ScotsDragon's Avatar
    Aug 2009
    Lost in Time and Space...
    Trim : SRI
    Engine : 1.9 CDTI 150
    Mileage : 50000
    like this one Lip Spoiler
    Sep 2012
    liverpool
    it doesn't need repainting, just re clearcoating
  1. Exhaust paint, do I need to lacquer??
    By paul_sri150 in forum Vectra C / Signum Car Chat
    Last Post: 12th May 2012, 11:09
  2. lacquer like substance in egr
    By taxidriver50005 in forum Engine & Drivetrain
    Last Post: 6th February 2012, 09:15
  3. lacquer peal
    By marc vectra sri in forum Bodywork & Interior
    Last Post: 22nd July 2011, 15:13
  4. What Primer, Paint, Lacquer?
    By keith1983 in forum Styling
    Last Post: 3rd January 2009, 23:48
  5. Primer > Paint > Lacquer
    By Thomas1 in forum Vectra C / Signum Car Chat
    Last Post: 8th August 2008, 20:56
