Thread: Lights and other electrics cutting out when car is reved
    Sep 2012
    kirkby in ashfield
    Default Lights and other electrics cutting out when car is reved
    Hi
    I'm new to this forum lasy night the wife was driving home and the lights power steering just stopped working. Had greenflag out found the dreaded fault code p1109 i have have the car spanner light on a couple of time but it resets when you stop.anyway had a look and the swirl bar has totaly broken off ordering a new manifold tomorrow but would this cause the electrics to cut out?
    Dec 2011
    Seaham
    Alternator on its way out?
    Sep 2012
    kirkby in ashfield
    No had a new alternator about 8 months ago. Green flag tested it and it was fine
    Full Member plasma's Avatar
    On the Forum
    346 Post(s)
    Engine : 150
    Mileage : 74000
    think P1109 is stuck inlet flaps? and no that wouldnt cause the problems your having.
    Feb 2011
    Selby
    A poor battery can cause the dimming to occur, as it's purpose once the engine is started is to smooth out increases in demand from the electrical system. Also check the earth connections from engine to bodywork are in good condition.
    Sep 2012
    kirkby in ashfield
    will check earth connections a the weekend while doing the inlet manifold. battery was a new when the alternator was changed. Guess im going to have to get it checked out when its running could be anything from a loose connection to a relay. What ever happened to the day when you could count the wires under your bonnet on one hand.
    Regular Member mrk's Avatar
    Vehicle : vectra hatchback
    Trim : improving
    Engine : 1.9cdti mas remap
    Year : 06
    best of luck with manifold m8 i hear its a pig of a job
    Sep 2012
    kirkby in ashfield
    Quote Originally Posted by mrk View Post
    I'm not doing it one of the hgv fitters from work is doing it he's had a look and said it should take about 3 hours.
    Regular Member john norris's Avatar
    Jun 2012
    lancashire
    Quote Originally Posted by daftladd View Post
    theres a how 2 on manifold 2 guys 5 hour if i remember correctly one was experienced at them too
  1. 2007 Vectra Design 1.8 vvt electrics / engine cutting out
    By mk2cav in forum Electrical & ICE (including SatNav)
    Last Post: 31st October 2012, 20:29
  2. 1.9 150 cutting out
    By japkadett in forum Electrical & ICE (including SatNav)
    Last Post: 17th May 2012, 21:26
  3. lights/all electrics flicker when moving steering??
    By paul4400 in forum Electrical & ICE (including SatNav)
    Last Post: 10th February 2011, 00:30
  4. Vectra C - 2002 - Electrics Cutting Out.
    By Nicko_12345 in forum Electrical & ICE (including SatNav)
    Last Post: 28th September 2010, 17:43
  5. Cdti 150 spanner light flash when reved and very jumpy cough
    By Al 150 cdti in forum Engine & Drivetrain
    Last Post: 29th July 2010, 11:53
