Results 1 to 2 of 2
Thread: vectra c dti
    Jan 2010
    norfolk
    Default vectra c dti
    hi my vectra dti 2.0 on 53 plate has intermittant spanner light on and limp mode , put op-com on and fault came up p1105 - fa baromeric pressure to boost sensor what does this mean thanks
    Regular Member C-Owner's Avatar
    May 2011
    South London
    Quote Originally Posted by octoman View Post
    hi my vectra dti 2.0 on 53 plate has intermittent spanner light on and limp mode , put op-com on and fault came up p1105 - fa barometric pressure to boost sensor what does this mean thanks
    Related to>
    Air leak in the vacuum system.
    MAP sensor.
    Check the vacuum pipes and elbow joints for splits etc.
    Clean the MAP sensor with some carb cleaner.
  1. mods could i do to my vectra 1.9cdti vectra suggestion of cheap vxr bumpers
    By lynchy-- in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2013, 00:17
  2. Vectra b rose bush for vectra c rear upper control arm
    By supernova_abh in forum Suspension, Wheels & Brakes
    Last Post: 14th September 2012, 19:26
  3. Silver Vectra (Vectra C Sticker) Southport Ocean Plaza DU56
    By mishima in forum Spotted or put a flyer on a Vectra C/Signum or Insignia?
    Last Post: 29th September 2011, 23:25
  4. Replies: 9
    Last Post: 17th July 2009, 12:07
