Thread: EHPS Pump very noisy
    Sep 2012
    Swindon
    Default EHPS Pump very noisy
    Hi Everyone,
    Im Alan and I drive a 2003 Signum 2.2 Direct, I have a problem with the EHPS on the car, originally the pump suddenly became really noisy when the steering was turned, the steering felt as normal, I checked the fluid level and it was fine, went to the local dealer and they advised that the pump needed changing, I bought a second hand pump and installed it as per the instructions on TIS2000, bled the system and the second hand pump made just as much noise as the old one. Bought another second hand one and installed it yesterday, bled system and this one makes just as much noise, Is there something im doing wrong? The steering is as light as it should be, is it that im really unlucky and have bought 2 knackered pumps, or do I need to do something else for the pump to be as quiet as it was before the original one packed up. By the way its the pump that sits under the o/s light. Any help with this issue will be much appreciated as its getting very irritating now.
    Thanks, Alan
    Aug 2012
    What kind of noise is it? Are you sure there are no problems with the steering in general that maybe causing to much load on the pump?
    Sep 2012
    Swindon
    Its a loud whineing noise, like the sound a pump makes when it has no fluid in, gets louder when the steering is turned, but when the engine is idle you can hear the pump whineing, the steering is fine to turn.
    Sep 2012
    Swindon
    I have just unplugged the Angle Sensor on the rack and the pump is a lot quieter, get the steering wheel icon on the dash, which is expected, does this mean it needs replacing or just re-configuring does anyone know?
    Sep 2012
    Swindon
    Still got a problem with my steering, I managed to find that the inlet pipe was bent and was restricting the fluid in the system, had the pipe repaired and the steering was fine, no noise at all, turned car off and back on about half hour later and the noise was back, but now when steering is on full lock the pump makes a loud sucking noise and goes quiet and the steering wheel kicks back. Can anyone give me some advice as what to check and change now.
    Thanks, Alan
  1. fuel pump in tank noisy
    By dbgb25 in forum Engine & Drivetrain
    Last Post: 30th April 2012, 15:00
  2. electronic powersteering pump (EHPS)
    By vectra3.2dave in forum Vectra C / Signum Car Chat
    Last Post: 3rd August 2010, 00:32
  3. EHPS Pump problem maybe
    By skutters in forum Electrical & ICE (including SatNav)
    Last Post: 11th June 2010, 15:48
  4. EHPS Light
    By Piston broke in forum Vectra C / Signum Troubleshooting
    Last Post: 10th May 2010, 14:01
  5. Noisy pulley/water pump
    By rosssri in forum Engine & Drivetrain
    Last Post: 18th December 2007, 11:03
vauxhall ehps noise
