Thread: vectra sri cdti 150 remapping what's your thoughts please
    taunton
    Default vectra sri cdti 150 remapping what's your thoughts please
    about 13 months ago i had new inlet manifold EGR valve because it was swirl valves bar was broke off needed to be replaced had it all dune at dealer cost me quite a bit. iv been reading about remapping and blanking the EGR valve out of ecu spoke my mate who did work for merc and he said get it mapped out you don't need it the problem you had with the inlet manifold will only happen again they block up. so i found a guy that dose remapping spoke to him about it and he can blank out the EGR valve and give me more torque and make it run smoother and be better on fuel
    any thoughts
    South Central England
    17 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    If you are asking about egr blanking and mapping out, my opinion is that it is a must.
    Mapping for performance gain is a different question but the egr would be best blanked standard or tuned.
    New Member brooxy10985's Avatar
    Sep 2012
    Trowbridge, Wiltshire
    I wan't aware the car had to be remapped if egr is blanked off. Would this explain why i get slight flat spots on boost sometimes?
    17 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    You should get a fault light if you have blocked the EGR but the EGR does not opperate near full load, so it should not effect performance.
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Quote Originally Posted by brooxy10985 View Post
    It doesn't, the remap just removes the EGR operation from the ECU which removes the emissions light.
    taunton
    hi Dan seen you had a remap on your vectra and you are pleased with it, i get mine done on the 29th of this month with the EGR removed from ecu to stop all the oily deposit going in to the manifold after reading the right up about yours i think i am going to like it roll on the 29th
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Had my map for 1year/13k now and I have to say I'm well have. Best money I have spent. EGR valve blanked and remapped off car still going strong.
  1. CDTi remapping
    By Derek Mc in forum Insignia car chat
    Last Post: 18th December 2012, 21:57
  2. Vectra cdti, ECU removal for remapping??
    By phil147 in forum Engine & Drivetrain
    Last Post: 5th May 2011, 11:52
  3. Remapping V6 CDTI ?
    By E5CDW in forum Diesel Engine related
    Last Post: 23rd May 2010, 17:16
  4. Remapping 1.9 (8V) cdti 120
    By Kieran1981 in forum Diesel Engine related
    Last Post: 5th April 2009, 19:03
  5. Remapping 1.9 cdti
    By Steel in forum Diesel Engine related
    Last Post: 14th February 2008, 19:22
vauxhall vectra 1.9 cdti sri 150 remap
vectra sri remap
vectra c remap
vectra c 150 tunning
vectra 1.9 cdti 150 remap
vectra sri 1.9 remap
vectra cdti remap
Vectra 1.9 cdti remap
remapped vectra c cdti sri 150
signum cdti 150 remap
vectra c cdti remap
Vectra c cdti 150 tuning
remap vectra 150 sri
vectra c 150 remap reviews
