Thread: Fuel Trim Malfunction and idle problem after plug and oil change
    Regular Member v6vc's Avatar
    Jul 2009
    Planet Earth
    Vehicle : Vectra & Signum
    Trim : GSi & Design
    Engine : 3.2 V6 & 2.8 V6 T
    Year : 02/07
    Default Fuel Trim Malfunction and idle problem after plug and oil change
    Hi everyone!
    Has been quite a while since I have posted on here!
    I changed the plugs and the oil today but after putting everything back together, I've got the problem.
    It's a GSI so the 3.2 V6.
    Plugs were changed from standard VX plugs to Denso Iridiums.
    On first start, it was idling really lumpy, next start was idling at 1,500 rpm and now after a drive, I have the fuel trim malfunction on both banks and a 1,500 rpm idle.
    It's got to be something I have done but I don't know what.
    So far I have:
    Checked that all the vac hoses I took off are now back on
    Checked the gasket on the TB
    Taken the chamber cover off and the black thing inside, reseated.
    Any ideas? I'm hoping it's not the plugs, wouldn't have thought that they would cause an idle problem so I'm thinking of an air leak but don't know where/what to check.
    Thanks in advance
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 136000
    i would change the plugs back to what you had in
    to eliminate them
    Jul 2009
    Planet Earth
    Trim : GSi & Design
    Year : 02/07
    Cheers. Do you think the plugs would cause an idle problem though? Don't have any misfire or anything like that.
    I've been out to car and sure I can hear a hiss so guess it is an air leak. Will take it all back off tomorrow and see if there is an inlet gasket blow or something.
    Jul 2009
    Planet Earth
    Trim : GSi & Design
    Year : 02/07
    Spent the morning looking into this problem and through a bit of trial and error, found out what was going on so reference ............
    When I put it all back together yesterday, I had 2 bolts that secured the black thing (have no idea what it's called!) in the chamber that wouldn't screw tight. That was the problem, unmetered air was being drawn in through there as the gasket wasn't sealed. I put bead of liquid gasket round the whole unit, let it dry and started. No hissing and a stable idle!
    Moral of the story, don't over tighten your bolts!
  1. fuel trim bank 1 & 2 and misfire due to low fuel
    By shaunft in forum Engine & Drivetrain
    Last Post: 30th August 2012, 15:40
  2. P0380 Glow Plug/Heater Circuit "A" Malfunction
    By sinless in forum Vectra C / Signum Troubleshooting
    Last Post: 9th March 2012, 21:38
  3. P0380 Stored Glow Plug/Heater Circuit A Malfunction
    By frag45 in forum Engine & Drivetrain
    Last Post: 5th January 2011, 13:01
  4. Fuel trim malfunction
    By tommyk999 in forum Engine & Drivetrain
    Last Post: 20th June 2009, 15:32
opel vectra 3.2 fuel trim bank 1 and 2 malfunction
vectra c fuel trim malfunction
mafunction 1500 rpm
vectra fuel trim malfunction
