Thread: vectra c 2litre turbo idle problem and engine cut out HELP
    Regular Member davedave's Avatar
    Apr 2012
    manchester
    Default vectra c 2litre turbo idle problem and engine cut out HELP
    Hi people
    currently have a vectra c 2litre turbo, ive noticed that it is idling up and down on tick over, also sometimes when i slow the car right down and go round a corner to come to a stop the engine has started to cut out.any help anyone, i have tried a fuel system cleaner and recently been serviced, but still happening,
    cheers, hope some one can help.
    South east
    You need to have the idle speed increased by someone who has a Tech2 device. It's a Saab engine, and that's the official Saab fix for those symptoms.
    Regular Member benholden2010's Avatar
    Oct 2010
    middlesbrough
    There's a couple of people having this problem atm, there dosent seem to be a deffernat fix but I'd try a good service, clean throttle body and butterfly valve etc. The fact its actually cutting out could also point to a faulty mass air flow sensor.
    As for increasing the idle speed, I've never heard this one mentioned but its certainly worth a try.
    Don't forget keep us updated if you get to the bottom of it
    South east
    Quote Originally Posted by benholden2010 View Post
    There is indeed a definite fix, it's mentioned in WIS - Saab's workshop programme.
    Regular Member richedition100's Avatar
    Dec 2011
    Shropshire
    Vehicle : SRi T Edition 100
    Engine : z20net
    Mine does the same. It's embarrassing when I stall it! Also the idle problem seems worse since I had new sport backboxes.
  1. Location of the egr valve on a vectra c 2litre turbo 07 plate
    By davedave in forum Engine & Drivetrain
    Last Post: 12th September 2012, 21:18
  2. Vectra c 2litre turbo throttle body and idle air valve , clean
    Last Post: 10th September 2012, 21:11
  3. Idle problem, loss of power, engine management light on.
    By Coyney in forum Engine & Drivetrain
    Last Post: 10th July 2011, 10:57
  4. 2litre turbo emissions light problem...aaaargh
    By voxpop in forum Engine & Drivetrain
    Last Post: 2nd March 2010, 18:29
  5. Replies: 4
    Last Post: 31st July 2008, 15:29
