Thread: Would you replace oil filter housing??
    Full Member
    Nov 2009
    Warrington
    Default Would you replace oil filter housing??
    morning peeps. I'm due to do an oil change on my 1.9 cdti vec . I do this every 6 month. 6 month ago I did the interim service myself as vx wanted silly money. After I changed the oil I noticed a very slight oil leak around the filter housing so I removed the filter and replaced the two I rings incase I split one of the new ones whilst fitting. Anyway the leak was so small I just forgot about it and when I came to check again about a month later it had stopped. I'm wondering if it's a good idea to get a new oil filter housing incase I get the same problem again, I think I may have overtightened this housing a little in an attempt to stop the leak.
    VIP-Member antowens's Avatar
    Dec 2011
    liverpool
    the o ring might of been sitting funny causing it not to seal properly and after time it has sealed it self if you want peace of mind mate change it but if it hasnt caused you no bother last time then just get a new o ring tighten up and on your way just your preference mate if it was me i would change it wouldnt imagine it to cost much thats assuming its like the petrol on were its a paper filter with a plastic housing over the top ?
    Full Member
    Nov 2009
    Warrington
    Quote Originally Posted by antowens View Post
    yes it's plastic, think its about £30 from dealers
    South east
    Use the same housing, change the o-rings and remember to smear them with new oil before fitting them.
  1. 3.0 d Oil filter housing
    By Faz2726 in forum Y & Z30DT Specific
    Last Post: 14th February 2013, 17:06
  2. help me please oil filter housing
    By kamazoo in forum Vectra C / Signum Car Chat
    Last Post: 28th July 2012, 22:03
  3. GSI Oil filter housing
    By sickboyjay in forum Engine & Drivetrain
    Last Post: 23rd March 2011, 15:06
vectra c small o ring on oil filter
