Thread: DMF or Release bearing.. please confirm
    Jun 2012
    Lincs
    Default DMF or Release bearing.. please confirm
    Morning guys, i feel i have a big repair bill up ahead.
    Basically i start the car in the morning, it sounds just like it should. Once its warm and the car is on tick over i can hear the dreaded groaning sound from within then engine bay.
    Once i press the clutch fully down again the noise disappears and sounds normal again. If i hold the clutch biting point thats when its at its worst.
    Also as read on here at low speeds it can be a little juddery and also hesitant between 1500 and 2000rpm although i think this is a different probelm
    Please can you confirm which has failed although i will be doing the flywheel if the box is out, just want to know which has given up. thanks
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Flywheel going by sounds of it.
    But tbh it's false economy not to change everything while box is out.
    So flywheel, clutch(pressure and friction plate) and CSC
    Jan 2012
    Milton keynes
    Trim : M Sport and Design
    Mileage : 38100
    Is the CSC the same as the release bearing or thrust bearing (What ever its called)?
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Yes mate
  1. Clutch Thrust Release Bearing Perhaps.?
    By sootyville in forum Engine & Drivetrain
    Last Post: 24th July 2011, 07:58
  2. clutch release bearing
    By martin_SRI in forum Engine & Drivetrain
    Last Post: 20th December 2010, 21:37
  3. clutch release bearing
    By pizzajazz in forum Vectra C / Signum Car Chat
    Last Post: 11th January 2010, 17:36
  4. Clutch release bearing help 3.2 GSi
    By leeroberts919 in forum Engine & Drivetrain
    Last Post: 29th June 2009, 10:52
does a dmf have a release bearing
