Thread: Brushing noise from front (repetitive noise on every rotation of the wheels)
    Chelmsford
    Default Brushing noise from front (repetitive noise on every rotation of the wheels)
    Been noticing this very annoying noise since I replaced my front discs and pads a couple of weeks back.
    Sounds like something is rubbing, but I can't find out what.
    Most noticeable when turning right at slow speeds oddly...
    Anyone got any ideas?!
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    maybe you wheel is rubbing the wing or the side of the arch i would have a good look around to see if you can notice any rubbing
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Sounds like the shield on behind the brake disc is touching the disc. It'll sound worse when turning a certain way as the disc will be getting forced harder onto the shield
    Simple fix if it is, jack the car up, take the wheel off and bend the shield back a bit
    Chelmsford
    Cheers for the ideas guys.
    I did wonder about the shield as it's happened in the past (ruined a brand new disc!). I'll take a look.
  1. Wheel Alignent or New Tyres? Noise Noise Noise
    By lostdog in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2011, 13:29
  2. Loud noise from front wheels! Please help me! :(
    By Kristypie in forum Suspension, Wheels & Brakes
    Last Post: 30th January 2011, 18:34
  3. Noise from front end of Vectra through wheels ?, help please
    By da_melonuk in forum Suspension, Wheels & Brakes
    Last Post: 20th April 2010, 19:17
  4. Noise from wheels - again
    By neilgsi in forum Suspension, Wheels & Brakes
    Last Post: 17th August 2008, 10:06
  5. 1 noise solved (front Bearing) + 1 new noise (squeaking front brakes!!!)
    By joseantoniovalle in forum Suspension, Wheels & Brakes
    Last Post: 30th September 2006, 08:54
