Page 1 of 5 123 ... LastLast
Results 1 to 10 of 41
Thread: No power.
    Mar 2011
    belfast
    confused No power.
    Hi everyone.
    have a prob with my 1.8 vvti sri.
    i fitted a replacement engine and gearbox 4 weeks ago and all was fine.
    over the last 2 weeks ive noticed that there is no power in 2nd or 3rd gear when i put the foot down.
    i put it down to the air pipe coming from MAF to the Throttle body as it was cracked so i ordered a new one and fitted it earlier.
    once i started it earlier the car/spanner light came on and stayed on for 5 mins then went off, WTF???????
    the thing is, its still dead in 2nd and 3rd.
    the new engine and box came out of a 2010 zafira with only 22k on it.
    when fitting it i only had to change over the throttle housing as the pipe work was different, and the sump as mine had a sensor on it.
    their is no EML on and it sounds like a new engine and drives well but just no power when needed.
    has anyone any thoughts on this???????
    Aug 2012
    Maybe worth checking the fuel filter. Does it rev fast and smooth with no load?
    Mar 2011
    belfast
    Fuel filter is fairly new, Im going out soon to take off the throttle body and give it a good clean, and change the plugs to see if this changes anything.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 141000
    Barrow In Furness, Cumbria
    I was going to advise as above. You need to get the code read and see if it is the same as the code I was getting.
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    As its come out of a Zafira are the ratio's the same
    Dec 2011
    Seaham
    Do you get a top end rattle on start up?
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 141000
    what is it with the 1.8vvti lately
    there are a few problems going around
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 141000
    from chris sri post
    I've just been out and checked and this code is stored:
    P0011 - Intake Camshaft Phasing Mechanics Range/Perfomance (Bank 1)
    this was from chris sri code
    and benson had p0011 code the other week
    Dec 2011
    Seaham
    Tell me about it!!
  1. Replies: 17
    Last Post: 11th March 2015, 00:55
  2. Signum Sluggish low power, Limp mode at high power.
    By Bigg943 in forum Vectra C / Signum Troubleshooting
    Last Post: 6th June 2011, 18:55
  3. Signum Sluggish low power, Limp mode at high power.
    Last Post: 5th June 2011, 11:30
  4. Replies: 11
    Last Post: 7th January 2010, 17:50
  5. Power Steering Electrical Power Drain
    By AntB in forum Suspension, Wheels & Brakes
    Last Post: 1st November 2007, 16:03
