Thread: VXR Exhaust
    Aug 2011
    Bristol
    Default VXR Exhaust
    If I wanted a VXR exhaust for my Signum 2.2 Direct from the centre section would it fit straight onto the cat or would the pipe be bigger??
    Obviously the exhaust would be for an esate Vectra so would this be a straight swap or would it need to be adjusted or have differant mounting etc?
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Well the cat on the z22yh in on the down pioe the Vxr has a cat and precat u could make it fit but it won't be straight swap some cutting is needed
    Blantyre
    I have a VXR fitted on my 2.2 Direct
    Joined at the down pipe just after the CAT
    Regular Member benholden2010's Avatar
    Oct 2010
    middlesbrough
    Got a vxr system on my 2.0 turbo, I needed a reducer but other than that it was a straight fit, the 2.2 should be the same, although I could be wrong :-)
  1. Exhaust hanger broken /rotted from exhaust.please help.
    By Dobs in forum Engine & Drivetrain
    Last Post: 25th January 2012, 21:06
  2. Duel exhaust - where to get a right hand exhaust heat shield
    By Innes in forum Bodywork & Interior
    Last Post: 29th November 2011, 00:47
  3. Fitting Dual Exhaust on single exhaust 2.2 sri
    By sdnatlst in forum Petrol Engine related
    Last Post: 1st February 2010, 10:49
  4. Where to buy oval exhaust tail pipes for signum exhaust
    By eaglepva in forum Vectra C / Signum Car Chat
    Last Post: 17th June 2008, 17:16
  5. Replies: 7
    Last Post: 22nd August 2007, 21:16
