Results 1 to 10 of 20
Thread: Police spec shocks?
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Default Police spec shocks?
    Just been looking through some part numbers and come across these,
    "2.2 hatch/saloon/estate man. police to '04 RH 93174099 £57.50 £48.90 £36.85
    2.2 hatch/saloon/estate man. police to '04 LH 93174098 £57.50 £48.90 £36.85"
    Shocks for the vec.
    What is the difference to the sport shock. I presume the sport shock is for all models fitted with sri/gsi suspension set up. Are these police spec ones an upgrade to them? If so is anyone using them?
    I use them occasionally at work!!
    I doubt there is a lot of difference (if any) to them to be honest... they are probably the same as the uprate ones you would get if you had the tow pack options fitted from new.... just allowing slightly more weight to be carried. Either that or they are the same as the SRi and GSi ones... as the Police Spec models are one off "special vehicles" from VX Special Vehicles and so don't have a specific spec (LS/SRi/GSi etc), so they list them separately so the suppliers can't get confused!!!!
    Vehicle : SRi
    Mileage : 137000
    Just had another look and the Police part numbers seam to be the same as the Sport.
    2.2 hatch sport to 31032140/38040655 RH 93174099 £57.50 £48.90 £36.85
    2.2 hatch sport to 31032140/38040655 LH 93174098 £57.50 £48.90 £36.85
    That would make sense.
    Vehicle : SRi
    Mileage : 137000
    Shame, thought Id come across a cheep little upgrade.
    Goes to show you dont get owt for nowt.
    Regular Member kgsric's Avatar
    Northants
    Regular Member VectraV6CDTi's Avatar
    Wilts
    Quote Originally Posted by kgsric View Post
    VAUXHALL VECTRA 2006 2.8 TURBO SRI .............. Interesting, so they take out the standard engine of a SRi and fit the 2.8 Turbo? Must cost a fortune to do
    Edit: Must have to uprate the shocks/brakes etc....... why just not start off with a VXR spec in the first place?
    Vehicle : SRi
    Mileage : 137000
    They used to drop in 3.2's into sri's for the police vecs up here. Its all done at the factory.
    They are all put together off the normal production line by a special department Vx have, so they are built to a spec that police forces will buy (SRi looks, SRi interior, VXR engine, brakes and suspension, Base model dash and audio, no trip computer, uprated electrics/alternator for sirens lights, radio etc etc.) Each one is 'custom built'.
    I was flicking through the manual in one of our Astra's and the book was all stamped up with "Vauxhall Specialist Vehicle Division" stamps.
    Regular Member Inspektor's Avatar
    Northampton (Santa pod)
    I get to see the police/ambulance spec Audi/VW/skodas. Some changes I notice as Jamie says is dropped specs like audio,Electric windows,airbags. They ARE chipped and tweaked with beefed up suspension and none have low profile tyres, Also they will not allow less than 5mm tread depth and all tyres have to be matching axle to axle. Some of the equipment they carry wieghs close to a ton Another thing on the police spec ones is they disconnect the fuel cut off switch.
  1. police spec vxr
    By Morephun in forum Vectra C / Signum Car Chat
    Last Post: 7th February 2010, 22:15
  2. 3.2 v6 SRI Police Spec
    By crash112211 in forum Cars for sale
    Last Post: 12th October 2008, 19:59
  3. New spec Police cars
    By SCOTTEX in forum North West (RO - Paulvectrac, ARO bonehead)
    Last Post: 24th March 2007, 05:02
