Hi,
I was wondering if the following accessories would fit in a Vectra that came without them:
Hi,
They will but the rear air vents will only probably work on a pre facelift Vectra not a face lift one iirc
The cup holder does cos I fitted one
Not sure if the air trunking for the back vents is in place on a car that didn't have them fitted.....
The cupholders will work but if you don't already have the rear vents then those won't work.
Only early cars and higher spec facelift cars had those fitted as standard and iirc you'd need to fit a new heater unit to allow you to fit them
See, Best to get an older model then you get all the toys as standard.
Thanks for the feedback
am sure someone got the rear vent working. theirs two venting parts to it.
How much would be a reasonable price to pay for second hand cup holder compartment (pictured above)? I've seen a few on eBay.
