Results 1 to 10 of 18
Thread: can MAF be cleaned & reused? or buy new one?
    Leicestershire
    Trim : PreFace SRi
    Engine : 1.8 LPG
    Year : 53
    Question can MAF be cleaned & reused? or buy new one?
    hi guys. i think my MAF is playing up. just wondering if i can clean and reuse it? or shall i just bite the bullet and buy a new SIEMENS one?
    Full Member spennny's Avatar
    Blantyre
    Am in the same boat mate , cars running slightly rich and the odd mid fire , not long after I oiled the K&N
    Sent from my iPhone 4s using Forum Runner
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 139000
    Quote Originally Posted by paz_badboy4life View Post
    have you got any codes
    like po170
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    I have successfully cleaned the MAF by simply spraying carb cleaner past it. This can be done either by spraying up the air intake or diconnecting the tubing and spraying after the filter,ie it wont strip the oil outta your k+n. You could allways just take the filter out and then spray.
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Spray electrical contact cleaner through it when off the car. Dont use anything else as it leaves a film and will kill the MAF.
    Leicestershire
    Trim : PreFace SRi
    Engine : 1.8 LPG
    Year : 53
    I've swapped my MAF with my uncles. It's defo the MAF that's causing me problems coz my cars fine now & my uncles vectra is messed up now lol. Just wanted to know if I could clean the MAF & reuse it to save myself £70. I've used the pedal method to find the codes, but i always lose count lol.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    You an electrical contact cleaner. An leave it's for a good few hours to fully dry before fitting back to car.
    Chances are though it's goosed an you need a new one
    Dont spray through the intake with air filter in place an the air filter will just absorb most of it.
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    If your sure its your MAF you got nowt to loose by trying.Personaly I 've never had any problems using carb cleaner on 5 seperate cars but its your choice.FYI Albert looms in Derby(big breakers) currently has two vectras in..I've never seen one in before in four years. IF you want me to get you one tell me your car spec etc and I will. Or go yoursen. Straight down M1 to Nottm junction. Left turn to Derby. As you hit Derby the first major turn off youll reach is for Spondon,left turn.Big Island 2nd junction.
    Leicestershire
    Trim : PreFace SRi
    Engine : 1.8 LPG
    Year : 53
    thanks for all the replies guys. i think im going to buy a new one off ebay soon, £70 genuine Siemens one. but my car still aint running right with my uncles MAF, its running a lot better, but now how it should. so will have to get diagnostics done on it tomorrow and hope for the best.
    Regular Member peadar's Avatar
    Aug 2007
    in the glens of Antrim N Ireland
    Vehicle : ELITE
    Trim : FULL LEATHER
    Engine : 1.9 CDTI 150 BHP
    Mileage : 87,000
    i done mine with brake & metal cleaner and worked ok
  1. All cleaned out!
    By multi in forum Quick Photo Album
    Last Post: 8th June 2009, 11:02
  2. Another cleaned Vec
    By carl bear in forum Gallery
    Last Post: 4th June 2009, 12:18
  3. cleaned the vxr
    By biglee55 in forum Quick Photo Album
    Last Post: 19th May 2009, 21:38
  4. Cleaned the VXR
    By BigP in forum Gallery
    Last Post: 29th April 2009, 21:43
  5. cleaned
    By topgun in forum Gallery
    Last Post: 29th March 2009, 16:39
