Thread: can anyone with tech2 help me with a aircon question?
    Regular Member Mads's Avatar
    Ipswich,.UK
    Default can anyone with tech2 help me with a aircon question?
    my aircon doesnt work, i got it gassed 2 weeks ago and it still doesnt work, could be leaking???
    checked fuses, all ok.
    pressed ac button on and off didnt notice any dips in revs and also compressor doesnt seem to be turning which could mean no gas in the system or duff compressor.
    my tech2 question is this.....
    are the below reading all normal for a/c?
    A/C Pressure (Air Conditioning) 140 kPa
    A/C Pressure (Air Conditioning) 0.3 V
    A/C Relay (Air Conditioning) Not Programmed
    A/C Cutoff Mode (Air Conditioning) Not Programmed
    A/C Information Switch
    many thanks
    Not Programmed
    Administrator plasma's Avatar
    On the Forum
    399 Post(s)
    Engine : 150
    Mileage : 74000
    think aircon pressure pressure should be about 600kpa at idle when not on rising to approx 2000kpa when fully running,
    the Not Programmed bits are showing because its opcom and on proper diagostics would read correctly, ie A/C Cutoff mode = Active (due to low gas),
    A/C Information Switch = Off ( i think)
    A/C Relay = Not active
    but your pressure does look low, did it work 2 weeks ago when it was done?
    Ipswich,.UK
    Quote Originally Posted by plasma View Post
    the missus took it to be gassed and she said it was freezing, i never drove the car until about a week later and noticed it was the same as not having the aircon on.
    the 140kpa was with it on, didnt try with it off, but compressor isnt turning mate but believe that could be because the gas has all come out
    On the Forum
    399 Post(s)
    Engine : 150
    Mileage : 74000
    yep, looks like your condensor is probably goosed, 90% of the time the cause of leaking gas... You need it pressure tested rather than vacuum tested to hear a leak or check for the dye or residue of aircon gas (yellow/green colour)
    Ipswich,.UK
    I pressed one of the valves and a yellow/green gas/liquid came out but stopped after a few seconds, where is best to get it pressure tested mate and how much would i be looking at?
    thanks
    Ipswich,.UK
    also im hoping when its all fixed the kpa will come back up??
    Ipswich,.UK
    cant see any dye anywhere either. pressure test may be best to go for first then.
    On the Forum
    399 Post(s)
    Engine : 150
    Mileage : 74000
    go to any aircon place and ask if they can pressure test rather than vacuum, check down the front of the condensor mate.... If u pressede the aircon refill valve in a) your lucky you havent got frostbite and lost yer fingers and b) it means the rest of the stuff has escaped.
    once the system is fixed it will be to be refilled again.
    Ipswich,.UK
    thanks mate, i put a thick rag over and used a screwdriver to press it to see if there was anything in it, not something i would normally do. will let you know how i get on, thanks for all your help.
    Ipswich,.UK
    anyone know the part numbers for aircon condenser seals please?
  1. Another aircon question
    By 111 in forum Vectra C / Signum Troubleshooting
    Last Post: 19th December 2011, 01:36
  2. another aircon question
    By kirky2k4 in forum Vectra C / Signum Car Chat
    Last Post: 11th April 2011, 01:38
  3. AirCon Question
    By RobW in forum Electrical & ICE (including SatNav)
    Last Post: 29th December 2010, 21:12
  4. aircon question
    By monty2000 in forum Vectra C / Signum Troubleshooting
    Last Post: 25th June 2010, 13:49
  5. Sorry Another Aircon Question
    By Craig1985 in forum Vectra C / Signum Car Chat
    Last Post: 15th May 2008, 11:14
opcom ac relay test
testing ac with opcom
airco not programend vectra c
aircon in opcom
opcom ac pressure
