Page 1 of 5 123 ... LastLast
Results 1 to 10 of 50
Thread: Port and polishing 2.0T?
    Dec 2005
    Stone, Staffs
    Trim : Edition 100
    Engine : 2.0T
    Default Port and polishing 2.0T?
    Hi Guys,
    My car is in the local garage getting the cam chain replaced. I got a phone call to say that im very lucky!!!. I took it in because the chain was very rattly, so they stripped it down and found a bolt had sheared off and it was the collar that sits around the bolt that was rattling. The other thing thats happened is, one of the lower chain guides had snapped and looks like most of it ended up in the sump.
    So to get the bolt drilled out, it looks like the heads going to have to come off which got me thinking of having ported and polished at the same time. So, can anyone recomend somebody to do this? name? number price? In the future im looking to get a TD04, bigger fuel pump/injectors and remapped. Was also thinking while the cams are out, I might get them reprofiled, again can anyone recomend someone?
    Regards
    Jim
    Jun 2009
    South Coast
    8 Post(s)
    Vehicle : Signum & Insignia
    Engine : POS derv
    just buy different cams from a saab place like neos, much cheaper and perfect for the car.. you can get it ported and polished but you would also need to get your inlet and exhaust manifold done as well, there is a bigger exhaust manifold that would be a better option.. porting and polishing is mainly seen on n/a road cars and will cost you a lot of money and see you little gains.. Its a turbo engine, just get a bigger turbo, much more bang for your buck..
    Dec 2005
    Stone, Staffs
    Trim : Edition 100
    Engine : 2.0T
    Jun 2009
    South Coast
    8 Post(s)
    Engine : POS derv
    bummer, thats the access hole to the chain guide bolt, looks like part of the chain guide is still there as well... surely a stud extractor guy could do that in situ
    Dec 2005
    Stone, Staffs
    Trim : Edition 100
    Engine : 2.0T
    The thought where the access to get a drill in and straight looks tight but this could be lifted with a trolley jack and maybe undoing an engine mount to give us the lift.
    also the thickness of the stud (look around 5-6 mil thick) to be removed and get a stud extractor in. another thing is the swarf flying around and landing somewhere dangerous,
    Im going on holiday for a week this weekend so ill have a look at doing when we get back one night during the week.
    Id rather try this as opposed to going the £1000 ish total of having the head off itto get it out.
    Thanks for the reply Nige.
    Could I ask also, when you got your turbo hybrid', did you just need to get a bigger compression wheel (16) to replace the (14) or was their anyo other parts to upgrade the turbo itself.
    As Ieve said im looking at getting the rest of the parts, injectors pump etc but wanted to know more about the turbo hybrid process. any numbers/prices would be greatful.
    Regards
    Jiim
    Jun 2009
    South Coast
    8 Post(s)
    Engine : POS derv
    I uograded the chra as well from an L to an HL. TBH its best to use an established upgrade kit like Maptun provide so you get maps and support. At the time I started doing mine I went with a saab aero stage 5 but am now at a stage 6. They do more specific vectra /signum stages now.
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    There's some info HERE on Port Polishing the NET head using an Alfa 2.2 gasket as a template.
    Dec 2005
    Stone, Staffs
    Trim : Edition 100
    Engine : 2.0T
    The head is now off. Had a good look at drilling it out in situ but, it just wasnt possible due to the size if the bolt to be drilled out and access. Its getting sent to a local specialist once stripped down.
    Whilst its off, the inlet and exhaust ports will be matched. I was thinking of having the valve oil seals replaced at the same time but, as the old saying goes "if it aint broke.....".
    As for cams as suggested, im at a bit of a crossroads:
    I want to get some cams from Neo Brothers (Thanks very much Nige for the recomendation) and fit them now but, they would'nt need mapping in?.
    Or
    Wait and get bigger cams and a TD04-16HL turbo plus all the other bits like the fuel injectors/pump etc. but this of course is down to money which I cannot budget for at the moment because of taking the head off.
    Basically I want to do as much as I can whilst the head is off.
    Nige, did you get all the turbo components from Neo Brothers? If not could you supply links and prices if poss please.
    Thanks for the link Rushy, some very useful info on there.
    Thanks for all your help and suggetions
    Jim
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Depends what type of power ya wanting to get if your gonna be happy with 250 or so forget cams if you wanna go more then do the cams
    Dec 2005
    Stone, Staffs
    Trim : Edition 100
    Engine : 2.0T
    Hmmmm not really thought about figures to be honest. May well just stick with getting the turbo as this is what I had originally thought of doing.
  1. da polishing
    By vinty firth in forum Northern Ireland (RO - Vacant)
    Last Post: 26th July 2012, 11:15
  2. Iso Port to Quadlock Port
    By Jez1516 in forum Electrical & ICE (including SatNav)
    Last Post: 3rd December 2011, 01:35
  3. Polishing
    By Tony1969 in forum Detailing and Car Care Discussion
    Last Post: 3rd December 2009, 22:24
  4. car polishing
    By happypostie in forum Detailing and Car Care Discussion
    Last Post: 13th February 2009, 18:40
  5. Polishing day
    By grumpano in forum Quick Photo Album
    Last Post: 10th May 2006, 16:24
