Thread: carbon fibre film how to apply it?
    Regular Member mrk's Avatar
    Vehicle : vectra hatchback
    Trim : improving
    Engine : 1.9cdti mas remap
    Year : 06
    Default carbon fibre film how to apply it?
    i've got the pre cut kit ,mirror bases,door pillars etc just wondered if it is dead easy or is there a nak to doing it,any advice welcome cheers
    Regular Member baz2003uk's Avatar
    Mar 2007
    swindon
    not sure about this ready to fit stuff but the stuff on a roll is easier to work with when warmed up with a hair dryers as you apply it
    Regular Member bigwilks's Avatar
    Jul 2011
    Nottingham
    Vehicle : 2003 GSi
    Trim : Star Silver GSi/VXR Half leather
    You need soapy water in a water sprayer make sure the area is clean from dirt and dust, spray the area with soapy water(not to much soap just a small drop to help lub the vinyl).
    you can just peel off the backing and lay on without it actually sticki straight away make sure its in the correct place then press it on with your hand while using something like a credit card rub from the middles out to squeez out all the water then leave to dry, as baz says if you need to form it around something a hair dryer to heat alittle helps alot
    Trim : improving
    Year : 06
    cheers chaps
  1. Replies: 4
    Last Post: 29th December 2012, 19:09
  2. Replies: 8
    Last Post: 20th August 2012, 08:09
  3. Carbon fibre film 130cm wide - where is it?
    By cont1204 in forum Vectra C / Signum Car Chat
    Last Post: 20th March 2011, 22:43
  4. carbon fibre film
    By bobssignum in forum Styling
    Last Post: 12th October 2008, 13:37
