Thread: astra vxr gearstick gaiter fitting
    Regular Member mrk's Avatar
    Vehicle : vectra hatchback
    Trim : improving
    Engine : 1.9cdti mas remap
    Year : 06
    Default astra vxr gearstick gaiter fitting
    lookng to fit mine next week just wondered if there was anything i could do now to make the swap easier,like altering the gaitor or anything else ,i have a spare surround if that helps
    cheers
    Blantyre
    Just use the plastic collar (bottom of gator) from the vec c stick mate , thats all
    Its all very easy
    Regular Member 130786howe's Avatar
    Nov 2010
    wales
    is the spare surround a vec 1 also u might just want to wait and do it at all at once its easy once you have swaped the surround over if its a vec surround you have then fit it ready on the vxr stick assuming you got astra one at the mo then its just a straight swap
    Trim : improving
    Year : 06
    i've just removed the shiny surround off the astra stick and test fitted the vec one it looks like i have to remove the staples from the plastic bit and re-staple the vec one to hold it in the correct shape if that makes sense
  1. Astra H gearstick
    By michael_linford in forum Styling
    Last Post: 10th January 2013, 20:21
  2. Astra h gearstick
    By RBH in forum Bodywork & Interior
    Last Post: 27th October 2012, 14:39
  3. Fitting an astra gearstick
    By dilan in forum Bodywork & Interior
    Last Post: 9th July 2012, 17:34
  4. Is it Astra h or Astra j gearstick that fits vec c
    By jon1.9cdti in forum Bodywork & Interior
    Last Post: 10th May 2012, 07:28
  5. Fitting new gear gaiter
    By david173 in forum Vectra C / Signum Car Chat
    Last Post: 14th May 2008, 16:22
how do you fit gearstick gaiter to vectra cdti
astra vxr gaitor
vectra c gear stick gaiter
