Thread: Oil Level warning light
    Aug 2012
    cheshire
    confused Oil Level warning light
    The yellow oil level warning chose to illuminate on the way to work today - I was on the motorway when it came on.
    I knew it to be false as I regularly check the level, there was no rise in temp/smoking/banging/ loss of power so I carried on to work.
    On arrival I let it cool and checked the level it was fine, the light never came back home on the way home.
    I guess I am now a fully fledged member of the forum as I have had my first electrical gremlin.
    South east
    There's no such thing as an oil level light - it's for the oil pressure, which is far more critical. Don't ignore it.
    Dec 2011
    Seaham
    Try cleaning the switch or for piece of mind, fit a new one.
    Aug 2012
    cheshire
    According to my handbook the yellow oil can is the oil level warning light - not to be confused with the red one which should go out during cranking.
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    I wouldn't have ignored it either way , i check my oil very regularly but if I got a warning on the dash saying my oil is low then I would be stopping to find out .
    there are plenty of things that can go wrong & empty the oil from the engine pretty quickly .
    just lucky for you that it was an electrical gremlin & not a genuine lack of oil .
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    I have a oil level light.. on the intrument. (and thats not the Oil pressure lamp)
    Glasgow
    I'm afraid there IS an oil level level warning. OP what engine do you have?
    VIP-Member antowens's Avatar
    Dec 2011
    liverpool
    mines the same came on half way down to sheffield kept an eye on the temp never moved got above 90 fan kicked in cooled it straight back down i knew the oil level was fine because i checked it prior to leaving mines a 1.8vvt i just put mine down to an electrical gremlin hiding under the bonnet somewere
    Quote Originally Posted by kenp View Post
    Me too. Had one on my 53 reg Elegance as well as one on my current 06 Elite. I thought it was a standard warning light on the Vectra-C models as well as the oil pressure warning light?
    Oct 2009
    Oxford
    Engine : 2.2i
    This used to keep happening on my old Signum (54 reg). When I checked I usually found that the oil level was OK. I'm sure that I found that it was a known 'feature' of certain models. I believe there is a redesigned dipstick or some such replacement to sort this out and that it might even be a free replacement item. Anyway once I found that it didn't mean my Signum was about to expire I stopped worrying about it and never bothered to investigate further.
  1. Fuel level warning light......
    By Nik in forum Electrical & ICE (including SatNav)
    Last Post: 20th July 2011, 00:44
  2. Intermitent Oil Level Warning Light - 2.8 V6
    By luke4487 in forum Engine & Drivetrain
    Last Post: 22nd May 2011, 15:06
  3. Coolant level warning light
    By phils in forum Vectra C / Signum Car Chat
    Last Post: 21st May 2011, 21:22
  4. Oil Level Warning Light issue
    By Blagmeister in forum Engine & Drivetrain
    Last Post: 14th March 2010, 18:23
  5. Oil Level Warning Light
    By Gogs67 in forum Engine & Drivetrain
    Last Post: 16th November 2009, 20:25
vectra c keeps showing oil level light but oil is ok
vauxhall vectra c low oil warning light
