Thread: Swirl Flap kit fitting
    Regular Member Casper85's Avatar
    Apr 2011
    Salisbury
    Vehicle : Vauxhall
    Trim : Vectra SRi
    Engine : 2.2direct Z22YH
    Mileage : 54600
    Default Swirl Flap kit fitting
    My Vectra is finally having the swirl flap mod kit fitted tomorrow.
    £194 seems a bit steep just for a plastic bar (actuator) and 4 plastic flaps with rubber parts, but if it eliminates my P1112 code problem then it was worth the money!!
    Has anyone else had any P1112 code problems after having the mod kit fitted???
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    I take it you found another volunteer Martin I didn't hear back from you.
    May 2011
    Ashby-de-la-Zouch
    Trim : sri nav/Elite
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    my new manifold cost about that new with my mates trade card. £320 including fitting.
    Apr 2011
    Salisbury
    Vehicle : Vauxhall
    Trim : Vectra SRi
    Mileage : 54600
    My local garage are doing it. Sorry Paulhb, I was waiting for a response from you as you mentioned possibly knwoing someone who can do it. Never mind, as long as the problem gets solved then happy days
    I didn't consider changing the complete manifold as plenty of people, including Vauxhall, told mefor my engine (Z22YH) the flaps can be replaced without manifold.
    That is, unless one of the flaps came loose and got sucked into engine!!.......
    26 Post(s)
    Vehicle : M5
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Crossed wires Martin I posted in your approach Vauxhall thread was waiting for a response still never mind
    Apr 2011
    Salisbury
    Vehicle : Vauxhall
    Trim : Vectra SRi
    Mileage : 54600
    All fitted for £144.00. The kit was £194.77. Fingers crossed that is the end of my Swirl Flap problems!! However, the mechanic did mention that if the light was to come back on for the same fault then could either be faulty ECU, seized Actuator motor or faulty wiring.
    Next job, fit the rear centre headrest and get the rest of the service items done. Although it has now been 2 years since last service (which was only an interim one) the car has only covered 9,000 miles.
    May 2011
    Ashby-de-la-Zouch
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    you cold of had a new manifold fitted like i said for that and had change leftover.
  1. swirl flap
    By elite lee in forum Vectra C / Signum Car Chat
    Last Post: 3rd July 2012, 21:49
  2. Fitting a Swirl flap actuator
    By jay w in forum Engine & Drivetrain
    Last Post: 17th May 2012, 06:41
  3. Swirl flap question?
    By Richard.roberts in forum Engine & Drivetrain
    Last Post: 5th March 2012, 18:48
  4. Swirl flap removal?
    By iaind84 in forum Diesel Engine related
    Last Post: 24th January 2011, 14:42
  5. Swirl Flap Problems
    By Lordnikon in forum Engine & Drivetrain
    Last Post: 12th July 2010, 09:44
