Thread: Is this an ABS Wire?
    Mar 2012
    London
    Default Is this an ABS Wire?
    My ABS light started coming on now and again and now stays on constant. Is this the culprit? Some one told me that was a brake wire.
    Had the wheel hub changed a month ago and the wire was left loose and must have rubbed against the wheel and worn off.
    Is it available seperately?
    Thanks.
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Looking good as the culprit. You should be able to trace the right cable from the small. black sensor head on the inside of the hub.
    Regular Member ftm100's Avatar
    South Shields seagull sh*t town
    if its part no 24418887 ive got one here you can have
    May 2006
    scotland
    To determine whether the wire is ABS or brake pad sensor, simply trace where the wire leads to at its lower end.
  1. What wire do I cut lol
    By roverjay in forum Electrical & ICE (including SatNav)
    Last Post: 8th November 2012, 09:01
  2. Which Wire ?
    By Ste in forum The 'Off Topic' room
    Last Post: 9th September 2012, 22:24
  3. 12 wire
    By decks in forum Electrical & ICE (including SatNav)
    Last Post: 16th December 2010, 22:02
  4. tel mute wire
    By jonesyboy in forum Electrical & ICE (including SatNav)
    Last Post: 6th October 2009, 22:33
  5. can you wire in an amp into....
    By jamesy in forum Electrical & ICE (including SatNav)
    Last Post: 12th February 2007, 18:23
