Results 1 to 10 of 20
Thread: driveshaft popped out
    Regular Member Swedge's Avatar
    Jul 2012
    Scottish borders
    Default driveshaft popped out
    i was changing the front struts on my cdti and the first side went fine but i managed to pop the driveshaft out of the outer cv
    its started to rain so came in for the day, will it be a driveshaft off job to get it back in? im guessing theres a circlip inside the cv that needs opening
    no , what should happen is when you stick the cv joint back onto the driveshaft the driveshaft has a chamfered edge which should engage inside the circlip and when you apply pressure it should open the circlip till the driveshaft will go onto it , the clicks into the groove on the shaft
    Jul 2012
    Scottish borders
    cheers i tried to get it back on but that was without undoing the big retaining nut first, im guessing ill need to undo that first to get the cv to push far enough on
    any idea on the size of the cv nut?
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    As Mark said some Cv's have a circlip that needs to be opened with circlip pliers - others can have a snap ring that allows you to pull it out or push it back in - it may be that you have the snap ring and you will be able to push it back in without removing the boot clip from the joint. Be very careful that you don't pull the joint to far apart and tear the boot or dislodge the boot clip
    Jul 2012
    Scottish borders
    ive already undone the clips that hold the boot on and slid it back a bit forbetter viewing, i have plenty cv grease to pack it with again
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    Quote Originally Posted by Swedge View Post
    You may get away without removing the large driveshaft nut by reassembling everything and tapping the end of shaft with a with a hammer - but put something between the shaft and your hammer to protect it from damaging the shaft
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    Sorry missed that one - be very careful you don't get dirt inside the joint - is it a circlip or a snap ring.
    Jul 2012
    Scottish borders
    Quote Originally Posted by alcutler View Post
    too much cv grease too see atm ill give it a clean up and pop it back on then grease it back up
    Admin plasma's Avatar
    On the Forum
    265 Post(s)
    Engine : 150
    Mileage : 74000
    vectra's use the snap ring type for the CV joints...
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    as dean says i did say circlip but its more of a snap ring that you can open with a screwdriver when removing it
  1. Osram nightbreakers have popped !!!
    Last Post: 31st December 2008, 18:32
  2. Just popped in.....
    By spoons in forum General Chat
    Last Post: 30th September 2008, 11:31
  3. Just popped in.
    By barney in forum General Chat
    Last Post: 12th March 2007, 12:46
  4. E/M - popped our cherries
    By JCB in forum 2005
    Last Post: 1st August 2005, 08:34
drive shaft nut size vectra c
insignia drive shaft popped out
drive shaft nut for vectra c driveshaft
