Thread: weird clicking when pulling off in first
    Jun 2011
    kent
    Default weird clicking when pulling off in first
    hello all
    im getting a weird clicking when pulling off in 1 and changing into 2nd i went to VX and they said its the drive shaft flexing :s since when does a solid bar flex..... ha but ok, please can someone give me some advise, im sure this happens in all gears but as the road noise gets louder you cant hear it. if it helps i will record the noise and put it on later, but it comes from the centre/right
    thanks in advanced
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 141000
    Regular Member amand's Avatar
    Feb 2011
    west London
    could be radiator mounts, or in my case it turned out to be a faulty ball joint. only took it seriously when my wishbone bush fell off.
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    A shaft CAN flex quite easily. The perfect example would be a torsion bar. In the case of a driveshaft though, I think the Vx guy might've actually meant one or both of the joints at either end. If you can narrow down if the noise is linked to wheel speed or engine speed you'll stand a better chance of tracing it. Also if it occurs only when moving forward or equally in reverse. Likewise only when in drive (in gear, foot off clutch) or does it stop if you floor the clutch? Always possible it might be a universal joint failing.
  1. Weird clicking noise from heater control or glove box
    By rollercoaster63 in forum Electrical & ICE (including SatNav)
    Last Post: 15th March 2018, 16:55
  2. Weird Clicking noise
    By Bloicy 3.2 V6 GSI in forum Electrical & ICE (including SatNav)
    Last Post: 18th June 2010, 22:29
  3. Weird Clicking / Rattling
    By spida_singh in forum Insignia car chat
    Last Post: 16th April 2010, 23:34
  4. car pulling in 2nd
    By Morephun in forum Engine & Drivetrain
    Last Post: 18th February 2009, 02:12
  5. Pulling Out Of The Pod...
    By Mark The Cabby in forum General Chat
    Last Post: 6th June 2006, 23:14
2010 insignia drive shaft clicking
