Thread: Service Indicator
    Regular Member Spelly's Avatar
    Derbyshire
    6 Post(s)
    Default Service Indicator
    Hi all, been trying to find out how many miles i have left till next service on my 52 plate gsi. Tried pressing the trip with ignition off and didnt work so tried it with ignition on and it displays three number, two numbers on bottom line and one on top in odo display. What do these numbers mean and what are they for ?
    Regular Member parapaul's Avatar
    Jul 2006
    It's something along the lines of the software version that's loaded, and/or the month & year of build.
    HTH
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Mileage : 137000
    Keys out and just hold mileage reset button down on clocks. If its getting close to your service, it will be displayed in mileage read out when you put the ignition on and when you turn the ignition off.
    Derbyshire
    6 Post(s)
    Thanks for the advice. I have tried pressing odo/trip with keys out and all i get is trip reset to zero and mileage displayed. It resets the inspection light when i press the odo and turn ignition on though. One thing i have noticed though is that when i unlock the doors with keyfob the odo lights up, is this normal !
    Regular Member ukanalyst's Avatar
    Jul 2006
    Cheshire
    Quote Originally Posted by Spelly View Post
    The trip shouldn't be able to be reset with the keys out ... sounds like a possible fault?? Daft question maybe but have you tried locking doors (out of interest does double locking work - two presses of lock button?) and then unlocking and then immediately press and holding the trip reset button?
    If you have done this then you will be unable to find out how many miles you have left until your next service using this method as it will have been reset
    Yes this is normal
    HTH
    Dave
    Derbyshire
    6 Post(s)
    Cheers Dave. Car locks with deadlocking and all appears normal and working. Will try what you said and see what happens
  1. service indicator
    By gizmo10119 in forum Electrical & ICE (including SatNav)
    Last Post: 2nd October 2010, 06:55
  2. service indicator on vec 2.2
    By pinnacare in forum Vectra C / Signum Car Chat
    Last Post: 10th August 2008, 00:29
  3. Service indicator
    By stanian in forum Vectra C / Signum Car Chat
    Last Post: 22nd February 2007, 23:17
  4. Service Indicator
    By VauxVeteran in forum Vectra C / Signum Car Chat
    Last Post: 12th February 2007, 20:29
  5. Service indicator
    By CPHB in forum Vectra C / Signum Car Chat
    Last Post: 4th February 2007, 14:41
