Thread: Which oil?
    Aug 2012
    South Wales
    Default Which oil?
    Was woundering if anyone can recommend the best oil oil filter and fuel filter to put in a cdti Sri 150 ?
    11 Post(s)
    Vauxhall recommend 5w/30 fully synth long life for all Vec-C and Signum engines.
    Their "own" brand oil is very good, as are their filters they sell. Prices competive with other car parts suppliers.
    Aug 2012
    South Wales
    Will magnetec hurt the engine
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    Quote Originally Posted by Mike1975 View Post
    Why do you think it would? As long as you buy the VX LL Specific Magnatec it will be good for the 20k service interval.
    Aug 2012
    South Wales
    The reason I ask few years back had a 51 plate vec b 2.2 Sri put magnetec in that and it was know good for the hydrolic adjuster for the chain 5 broke valves bye bye vec always used magnetec up till then just don't fancy frying another enging with it that why a want to make sure
    11 Post(s)
    If you've had a bad experience with magnetec before, why are you asking if it's ok to use this time?
    Surely your own experience should be telling you not to use it again.
    Use the stuff Vauxhall sell over their parts counter and you won't go wrong.
    May 2011
    Ashby-de-la-Zouch
    Trim : sri nav/Elite
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    magnetec is **** its part synthetic!
    11 Post(s)
    Quote Originally Posted by dan danz View Post
    Really?
    Perhaps they ought to be done by the trades description act then for lying
    http://magnatec.castrol.com/en/faqs/#10
    http://www.opieoils.co.uk/p-68941-ca...t-renault.aspx
    http://www.opieoils.co.uk/p-754-cast...d-by-ford.aspx
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Common fault on the 2.2 and could happen with any engine oil tbh
    There are plenty of threads on here about it.
    I use magnatec in my cdti and had I not just aquired some cheap Dexos 2 I would have used magnatec again
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 65500
    I believe there was a debate about this but it is now a proper fully synthetic.
    I have used mobil1, magnatec and dexos2 in mine, and by far the the magnatec was the quietest. I will be returning to using magnatec again for my oil change next month.
