Results 1 to 10 of 26
Thread: winding tool
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    Default winding tool
    how the hell do the brake winding tool work i have brought the draper one and dont fit ive chipped the piston slightly using grips were can i get a winding tool that fits the vectra
    Oct 2009
    Sandwell
    for the fronts
    VIP-Member GSiFan's Avatar
    Houghton Regis, Bedfordshire
    5 Post(s)
    Trim : GSi
    Mileage : 190,000
    I may be mistaken but I don't think you need a winding tool as such for the fronts. You just need anything that could drive the pistons into the calipers squarely. I have a tool for this from RS components. It is simply two steel plates with steel bar in between, one plain and one threaded. Two bars are used so that the affair stays true and square. You place it between the brake shoes and wind the threaded bar. The tool forces the pistons apart. I believe that people can and do use G-clamps to achieve the same ends.
    2003 Vauxhall Vectra GSi 3.2 V6
    Oct 2009
    Sandwell
    just watched a video on youtube ill get some better grips and place the old paon and do it that way
    Full Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    the winding tools are for the rears.. unfortunately a few of the winding tools listed for vectras are in fact for the veccy B and not the C..
    Ely, Cambridgeshire
    57 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Yup no wind in tool needed for the fronts, you only need the wind in tool for the rears.
    Dec 2011
    Seaham
    I use a G clamp to push the pistons back on brake calipers. I havent tried it yet on a Vectra.
    Regular Member Das's Avatar
    Here
    33 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    You can still use the wind back tools on the front though guys. You just need to use one of the larger plates.
    5 Post(s)
    Quote Originally Posted by Ben50n View Post
    Works a treat. I used those clamps that are similar in design to the mastic guns.
    wirral
    26 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    I just use a big flat blade screwdriver levering of the old pads far quicker an easier than clamps.
  1. inner tie rod tool
    By chris1804 in forum Suspension, Wheels & Brakes
    Last Post: 4th September 2012, 14:17
  2. Looking For a Tool
    By darrensten in forum Vectra C / Signum Car Chat
    Last Post: 20th June 2011, 16:58
  3. Caliper winding tool?
    By hardin in forum South West - RO (vacant) / ARO - (vacant)
    Last Post: 15th April 2011, 12:29
  4. winding tool for rear pads
    By myelite150 in forum Suspension, Wheels & Brakes
    Last Post: 3rd February 2010, 15:36
  5. Window winding down while away from car!
    By Adamant in forum Vectra C / Signum Car Chat
    Last Post: 26th October 2006, 16:00
vauxhall rear caliper piston trouble winding back site:www.vectra-c.com
