Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: VVt Cam Phaser Solenoids
    Dec 2011
    Seaham
    Default VVt Cam Phaser Solenoids
    I am having a few issues with the VVt, specifically it keeps throwing up Error codes for the cam solenoids. I have tried the field remedy by removing the filters, this helped slightly.
    An error code suggested that the Inlet solenoid was not working, so I have changed that.
    I am still getting error codes regarding the solenoids and have a "diesel death rattle" on start up. The car then runs for a short time and goes into limp mode. The last codes were
    P0011 and P0014, suggesting I still have problems??
    I have deleted these last codes and will wait for the EML again and check the new codes.
    Can anyone make any suggestions? Could it be the cam position sensor and if so where are they located??
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 131000
    P0011 A Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)
    P0014 B Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)
    i had my camshaft sensor go on my non vvti 1.8
    but it was P0340 Camshaft Position Sensor Circuit Malfunction
    Dec 2011
    Seaham
    Thanks, I cleared the codes and ran the car until the EML came on, now it is only reading the P0014 code, so it looks like I also need to change the exhaust solenoid.
    Strange how they both went at the same time?? Car has dopne 50k miles, maybe thats as long as they last??
    Dec 2011
    Seaham
    OK, received a the cam phaser solenoid today and fitted it, so far so good!!
    Full power has been resumed and no fault codes after about an hours running.
    VIP-Member antowens's Avatar
    Dec 2011
    liverpool
    So what was the cure exactly as mine is down on power now and agian code reader saying camshaft position sensors and its starting to really annoy me now same millage 50000 on an 06 plate was gunna try removing the filters tomorrow
    Dec 2011
    Seaham
    Try removing the filters first and give the solenoids a clean with a blast of carb/brake cleaner. The filters can get blocked if the oil has not been changed regularily.
    Otheriwse, simply change the the solenoids as you cannot strip the units.
    Do you also get a top end rattle/knocking at start up and the EML? It progressively gets worse!!
    Dec 2011
    liverpool
    i get the eml coming on and off every now and again an some times with run at full power and sometimes runs with a lack of power think it depends what mood the cars in an ye just seems like the engine ticks when ideling
    Regular Member Envy's Avatar
    Welwyn Garden City
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    Thanks for this thread Ben. I'm getting the rattle on start up (much worse than standard on 1.8 Vvt)
    Will give the solenoids a clean first and go from there. Car has done 90k so timing belt water pump plus other bits need to be changed as well. I wonder if that is contributing to the noisy starts in the mornings also.
    Dec 2011
    Seaham
    To Envy If the solenoids are sticking they starve the cams of oil, hence the rattle on start up. I would recommend trying the field remmedy first by taking the filters out, then if that doesnt work, simply replace the solenoids.
    To antowens, you need to remember that the engine will perform checks at different times, depending on driving styles. Once you have switchd off, it will reset the EML, however the codes will still be held. I had similar reults after changing just one solenoid, car was much better, but hen the exhaust one failed.
    I would recommend doing them ASAP.
    Dec 2011
    liverpool
    i have just took the filters of then an i can still here a ticking think i should give it a good blast down the motorway see if that clears it out abit ? and if that fails replace the solenoids ????
  1. Different Pt No.s for 1.8VVT Camshaft Solenoids
    By puppet in forum Engine & Drivetrain
    Last Post: 12th August 2013, 14:44
  2. Has anyone renewed a phaser pulley
    By Angel1368 in forum Engine & Drivetrain
    Last Post: 9th June 2012, 11:18
  3. Cam Phaser problems
    By mattc in forum General Chat
    Last Post: 7th January 2012, 00:48
how change a vectra cam solenoid
vectra c camshaft position solenoid
vauxhall vectra sri 1.8 solenoid cleaner
what does a vectra cam shaft solenoid
vauxhall vvt solenoid modifcation
vectra 1.8 sri vvt cam solenoid
vauxhall zafira 1.8 vvt resetting cam pulleys
vectra camshaft phaser
vectra vvt camshaft phasers
replace camshaft solenoid vauxhall
vectra c p0011
vauxhall vectra 1.8vvt resetting eml
vectra cam phase solenoid filter
how to take off camshaft solenoid vectra c
vwctra c p0011 camshaft position
how do you remove cam solenoide from vauxhall 1800 vvt
p0011 vauxhall vectra c
vauxhall vectra vvt cam phaser pulley
