Thread: Change of Screen CD30
    Regular Member 19CDTi's Avatar
    Jul 2009
    Perth, Scotland
    Default Change of Screen CD30
    Hi folks
    I have the CD30 unit with the 2 row small screen. Full CanBus.
    I've heard I can get the BC tech 2'd in, but I assume I need the 3 row screen for this?
    (like this one)
    http://www.vectra-c.com/forum/showth...-leds-set-no-4
    If so, can someone tell me what the 3 row screen is called and how I go about "pairing" a screen to the CD30 and will all the other gubbins (computer parts) be in place already? Bearing in mind the CD player has a BC button, but somes up "no function" when pressed.
    Thanks in advance.
    Stuart
    Regular Member wardy23's Avatar
    Nov 2011
    North Yorkshire
    Vehicle : vectra
    Trim : sri
    Engine : 2.2
    Mileage : 64000
    yes mate you will need the 3 row screen but its probably cheaper to buy another cd30 with the screen already paired together then there would be no need for the tech 2
    Jul 2009
    Perth, Scotland
    Good man, thanks Wardy, will get on the hunt
    Stuart
    Nov 2011
    North Yorkshire
    Vehicle : vectra
    Trim : sri
    Engine : 2.2
    Mileage : 64000
    Quote Originally Posted by 19CDTi View Post
    Stuart
    no probs mate
    scottish region
    Pretty sure it's a bid screen mate
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    GID screen is what you're looking for. If you're planning on upgrading the screen, why not up grade the headunit to a CD40 or CD70 too. The latter will also give you the colour display option too (CID).If you go down the route of upgrading the stereo/headunit you will need to make sure you get the screen that they are paired to.
    You can use a different screen with a different headunit (Only the CD70 can be used with the colour display though) BUT each screen and head unit must be divorced from their original counterparts before the can be married to next.
    If you just going after a screen make sure it has been divorced from its previous head unit and similarly make sure your current head unit is divorced form your old screen.
  1. For Sale: CD30 and screen
    By Rob12 in forum Parts for sale
    Last Post: 21st September 2012, 11:25
