Thread: Air filter cleaning
    Regular Member R-ford_Vec_C's Avatar
    St Helens
    Default Air filter cleaning
    This may be a daft question. but, how do you clean a K&N panel filter? Is it just a case of rinsing it under a tap, or do I need special cleaning stuff? Also, what is this air filter oil spray people keep mentioning?
    Ely, Cambridgeshire
    60 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Sep 2012
    expat Lancashire lad in the Midlands
    Engine : 3.2
    You need some special cleaning fluid, or a good oil and grease remover. Spray it on and leave it for an hour or so. Flush from the clean (throttle) side to the dirty (open air) side, otherwise you just drive dirt into the filter. Then dry thoroughly overnight. Then LIGHTLY oil it and allow the oil to work in.
    Jun 2006
    Lake District
    Vehicle : Vauxhall Insignia
    Engine : CDTi 160
    Mileage : 53.000
    or an old trick is to fill a bucket with red hot water and add a fair amount of good washing up liquid, and then soak the filter in that for about half an hour, then give it a good flapping about in the bucket, then rinse clean, leave to dry, then re-oil....sorted
    Ely, Cambridgeshire
    60 Post(s)
    Year : 2010
    Although it should probably be pointed out that the link I posted earlier gives full step by step cleaning and re-oiling instructions and states very clearly...
    The above process is the only approved procedure for maintaining your K&N Air Filter
    South east
    I spray a light coating of petrol on the filter and set light to the vapours. The flames burn all the dirt off.
    Not really.
  1. k&n filter and cleaning kit
    By Deztroyer in forum Parts for sale
    Last Post: 16th June 2010, 17:24
  2. K&N filter cleaning
    By aerodynamic18 in forum Diesel Engine related
    Last Post: 1st February 2009, 22:42
  3. K & N Filter cleaning kit
    By mushy2007 in forum General Chat
    Last Post: 23rd July 2008, 16:49
  4. K & N Air Filter Cleaning
    By cosmic in forum Vectra C / Signum Car Chat
    Last Post: 11th May 2008, 17:10
