Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: vectra c 2.0dti
    Aug 2012
    whitby
    Default vectra c 2.0dti
    hi all , i have a problem with my vectra dti y20dth , its done 69k on a 05 plate , it cuts out after about 10 seconds after starting it , hot or cold , it starts straight up each time , then when driving along its lumpy like it has a misfire, sometimes cuts out , replaced leak off pipes , crank sensor , cleaned egr valve ,no codes are present , been running around trying to get it to get the spanner light on , i called into a diesel specialist friday they have not seen this problem before , how hard is it having theecu tested on the fuel pump , any ideas anyone ,thanks .
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Was gonna say sounds like fuel pump Maye is there any codes present
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    sounds more like air leaking into the system , possibly at the filter , as a result the engine starts on the fuel that is in the pump & then cuts out once the air from the filter gets to the pump .
    Aug 2012
    whitby
    hi paulvectrac , no codes are present i took it 42 miles yesterday it was missing terrible , but light didnt come on , when it misses i can boot it and off it goes like clappers, i have noticed it misses
    while speeding up as well , got me stumped , i have had 3 fuel filters on all are clean
    dti elite , if air leaks into system would it be a ***** to start , it starts first spin off the key , this could be the case , when i first starting having this problem i cleaned the tank as good as i could put fresh diesel in it ran it then changed fuel filter ,
    Regular Member peadar's Avatar
    Aug 2007
    in the glens of Antrim N Ireland
    Vehicle : ELITE
    Trim : FULL LEATHER
    Engine : 1.9 CDTI 150 BHP
    Mileage : 87,000
    possibily crank sensor or very badly choked egr and inlet
    Aug 2012
    whitby
    well being out in car tonight no light came on but its put a code in P1222 , any ideas please .
    Aug 2012
    whitby
    code p1222 is pending ? .
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Well as I said that code is fuel injection pump I work on vectras and siggys every day 7 days a week lol is there anyother probs mate
    Aug 2012
    whitby
    all it says is intermitted fault injection , will post more tonight , thanks paul ,
    Aug 2012
    whitby
    managed to get it code read =swirl level control valve solonoid open , po660 .
  1. Vectra 2.0dti '52'
    By Craig_312 in forum Diesel Engine related
    Last Post: 24th February 2011, 11:31
  2. vectra c 2.0dti
    By cavie in forum Vectra C / Signum Car Chat
    Last Post: 29th November 2010, 20:25
  3. Vectra 2.0Dti 03
    By prm in forum Cars for sale
    Last Post: 30th March 2008, 21:02
  4. vectra 2.0DTI LS
    By Morephun in forum Vectra C / Signum Car Chat
    Last Post: 20th March 2008, 20:05
  5. vectra 2.0dti
    By mason_07 in forum Introduce yourself.
    Last Post: 11th November 2007, 10:56
