Results 1 to 10 of 13
Thread: Z19dth stuttering stationair when cold
    Sep 2010
    Netherlands
    confused Z19dth stuttering stationair when cold
    Hi,
    I have a question, my car is stuttering stationair (800- 2000 rpm = unloaded) when it is semi cold (when the motor temp = 30-40c?).
    When the motor is hot the motor runs perfectly.
    Yesterday i checked my injectors + renew 2 of them but still the same problem.
    Did somebody have an idea what this can be?
    Thank you.
    Robke
    Sep 2010
    Netherlands
    Hi i made a movie, maybe it more clear what i mean:
    Regular Member john506's Avatar
    Mar 2011
    Wirral
    Hope you get an answer cus I have the same problem.
    I was thinking maybe the glow plugs aren't pre-heating the cylinders up enough so the fuel isn't burning right? Then it levels out when the cylinders are up to temp
    Regular Member john norris's Avatar
    Jun 2012
    lancashire
    its the compression that triggers the burn the plugs only warm for the start up
    Mar 2011
    Wirral
    I see so as soon as the car starts then the cylinders are up to temp?
    Sep 2010
    Netherlands
    The problem is only there when the motor temp is <80 C.
    I think the motor is quit glowing their plugs at 70+ c?
    Jun 2012
    lancashire
    within a few seconds yeah
    Jun 2012
    lancashire
    by any chance have you checked to make sure the glow plugs have not come lose
    Aug 2012
    Quote Originally Posted by john norris View Post
    Yeah as John said car would run fine without plugs once it has started. In fact unless its really cold it doesn't really need them to start. I would check all your intake and exhaust manifold pipes as well as the seal around your injectors as a first port of call. All theses bits could get warm and seal up air leaks that will either be masked or eliminated once the engine parts heat and expand.
    Its also possible you have loss of compression on a cylinder (piston rings that expand and seal better) or that one of the injectors is under delivering, faulty or the connector is loose and the heat is just helping the item function better. I have heard there is a problem with the loom on older cars on Injector 3 - do you have the improved wiring loom? - something to look in to maybe?
    Please let us know if you sort it and what it was.
    Jun 2011
    brum
    Wish my diesel was that quiet :P
  1. Cdti stuttering
    By gtirobbie in forum Engine & Drivetrain
    Last Post: 23rd June 2012, 16:38
  2. Stuttering turbo
    By Ronnie-29 in forum Troubleshooting
    Last Post: 6th February 2012, 21:30
  3. Stuttering 2.2 Elite
    By Dogsbodyone in forum Engine & Drivetrain
    Last Post: 4th November 2011, 00:54
  4. Stuttering engine when engine is cold
    By chris_sri in forum Engine & Drivetrain
    Last Post: 3rd January 2010, 00:25
  5. 2.2 Dti stuttering under load - help
    By Boyden in forum Vectra C / Signum Car Chat
    Last Post: 20th December 2009, 20:51
vectra dti stutter when cold
